Adding speed camera POI to your SatNav DVD
#241
hi all,
after reading all this post and blowing up some dvds, everytime I do a search the list appears empty. I added 2 categories : 9000 for radars and 9001 for restaurants from Portugal.
any idea???...
any idea???...
#242
Hello All
New on here so go easy on me
Have a 525d v interested in speed camera on my professional Nav soon to be 2007-2.
If i understand correctly the following limitations still apply (in order of importance)
1) No audible warning approaching said device.
2) Dependent on software update have to turn speed camera icons on each engine start
3) All speed camera types have the same icon on screen
4) Need to burn new disk each time to update
So if 1) is still not solved/unsolveable could people report how easy it is to steam past a camera unnoticed. I would imagine quite easily!?
I currently have a Road Angel with plenty of subscription but am reluctant to mess the clean top of dash up, and increase my chances of being broken into. This unit works very well, but i am hoping for an integrated approach.
The best i can come up with is to mount the Road Angel out of sight, wire the sound to the vehicle's somehow???!! and use a combination of both devices. So 2 things to update..
Can anybody else shed any light on a better solution than the above.
Out of interest Road Angel are about to release an auto updating device with something similar to a sim card in it. The technology is in this car to do this. Mobile phone interface where specified, sat nav system - It must be possible to interface the two of them. Come on BMW are you missing a trick?? This could and should be on a car costing this sort of money at least as an option.
All suggestions welcome
#243
Well anybody got any info for me then?
I am still concluding Road Angel is the easiest way out, esp as my camera icons turn off every ignition offand are really quite cumbersome to re-enable.. Anyone then?
#244
For those of you with the new 2008-2 Professional DVD, I've just added some information regarding this version up at www.bmwnavaddpoi.co.uk
Very briefly, the folder structure has changed a bit and it is now a Dual Layer DVD.
#245
Hi - I have a 525 from February 08, and the 2008-1 dvd with it. I followed the instructions for the 2007-02 DVD --
I took the old dvd out, let my car "rest" an hour, and insterted the new "pached" DVD. All seem to go fine, after I chose my route the display turns blank and it seems asif the nav/idrive computer reboots (no music etc). This repeats over and over again, yet stops the moment I insert the original DVD
When I burned the disk I did not tick the joliet box. I have already created two discs with both the same results
Any suggestions from other members would be highly appreciated
Syd
Syd
#246
My Ride: BMW E60 530i, Production Date May 2005
Hi,
Thanks for the tutorial, but please, I need HELPPP!!!
I'm trying to add new GROUPS for:
GROUP - Petrol Stations - Individual 90001
POI's:
TPD-CAT 90101 N Ampol Service Stations
TPD-CAT 90102 N BP Service Stations
TPD-CAT 90103 N Caltex Service Stations
TPD-CAT 90104 N Mobil Service Stations
TPD-CAT 90105 N Shell Service Stations
I've created these entries in the Australian v14 BMW Professional Navigation DVD ENG.LSC file.
ENG.txt - make sure you rename it ENG.rar, it won't accept a .rar or .zip file upload.
I've created the .idx and .url using perl, created the SF_90101.htm - SF_90105.htm and ST_90101.htm - ST_90105.htm, added the ICON files, but when I access the CAR group where the Petrol Stations - Individual is located.
I've looked at the files etc., everything looks OK but the the CCC is very unstable and reboots when Navigation is selected even though it may display a map. I'm getting concerned about the reboots, after a couple, the screen didn't want to light up for quite awhile.
Is there anything obvious that I've overlooked, I want a add a stack of POI's and groups, but just having to sort through what the problem is with just the one group?
What's really annoying me, is I used the same process to add POI's including Groups to my OZ v12 Pro Nav disc.
Greatly appreciate any assistance.
Cheerz
- Traffic Cameras (not shown in this ENG.LSC to simplify)
- etc.
POI's:
Cheerz
Code:
#TPD-GRP <group-id> <category-id/another group-id> TPD-GRP 0 1 2 3 4 TPD-GRP 1 41000 47352 41008 TPD-GRP 2 10001 10004 10005 10006 10007 10008 10009 TPD-GRP 3 10002 10004 10005 10006 10007 10008 10009 TPD-GRP 4 10003 10004 10005 10006 10007 10008 10009 TPD-GRP 10001 40002 7387 11009 7311 90001 7395 TPD-GRP 10002 40003 7387 11009 7311 90001 7395 TPD-GRP 10003 7387 11009 7311 90001 7395 TPD-GRP 10004 11000 7312 7379 7352 11017 11011 7395 7316 TPD-GRP 10005 11021 9102 11016 7339 7365 11004 9111 11023 11006 7322 7324 11013 11018 TPD-GRP 10006 11022 11012 TPD-GRP 10007 9101 9121 11017 11010 11014 9112 7316 TPD-GRP 10008 11005 7317 11010 11008 9112 9125 TPD-GRP 10009 11001 11002 11007 11015 TPD-GRP 90001 90101 90102 90103 90104 90105 90106
Code:
TPD-CAT 90101 N Ampol Service Stations TPD-CAT 90102 N BP Service Stations TPD-CAT 90103 N Caltex Service Stations TPD-CAT 90104 N Mobil Service Stations TPD-CAT 90105 N Shell Service Stations
Code:
TPD-ICO 90101 /ICONS/poi_ampol.gif TPD-ICO 90102 /ICONS/poi_bp.gif TPD-ICO 90103 /ICONS/poi_caltex.gif TPD-ICO 90104 /ICONS/poi_mobil.gif TPD-ICO 90105 /ICONS/poi_shell.gif
Code:
SA 90101 10001 10006 SA 90102 10001 10006 SA 90103 10001 10006 SA 90104 10001 10006 SA 90105 10001 10006
Code:
IA 90101 20000 20001 20002 20003 20004 20005 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018 IA 90102 20000 20001 20002 20003 20004 20005 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018 IA 90103 20000 20001 20002 20003 20004 20005 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018 IA 90104 20000 20001 20002 20003 20004 20005 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018 IA 90105 20000 20001 20002 20003 20004 20005 20006 20007 20008 20009 20010 20011 20012 20013 20014 20015 20016 20017 20018
Code:
TPD-SEA 90101 http://tpdhost/cgi/form?templ=/ENG/S...TYNAME=%23%23N TPD-SEA 90102 http://tpdhost/cgi/form?templ=/ENG/S...TYNAME=%23%23N TPD-SEA 90103 http://tpdhost/cgi/form?templ=/ENG/S...TYNAME=%23%23N TPD-SEA 90104 http://tpdhost/cgi/form?templ=/ENG/S...TYNAME=%23%23N TPD-SEA 90105 http://tpdhost/cgi/form?templ=/ENG/S...TYNAME=%23%23N
Code:
# 90101 TPD-SEV 90101 INDEX_TABLE=TABLES/0/0901.IDX?URL_TABLE=TABLES/0/0902.URL # 90102 TPD-SEV 90102 INDEX_TABLE=TABLES/0/0903.IDX?URL_TABLE=TABLES/0/0904.URL # 90103 TPD-SEV 90103 INDEX_TABLE=TABLES/0/0905.IDX?URL_TABLE=TABLES/0/0906.URL # 90104 TPD-SEV 90104 INDEX_TABLE=TABLES/0/0907.IDX?URL_TABLE=TABLES/0/0908.URL # 90105 TPD-SEV 90105 INDEX_TABLE=TABLES/0/0909.IDX?URL_TABLE=TABLES/0/0910.URL
#247
Hi,
Worked it out, must've had a corrupt SF_????.htm or ST_????.htm that I edited to create the required .htm files.
Started afresh and all is OK.
Thanks for your help guyz.
Cheerz
Cheerz
#248
My Ride: E61 most options
The 2009-1 NAVDVD europe is available.
Has the same structure as the 2008-2 as far as i can see.
Looks like adding speedcams works in a similar way as the 2008-2 (haven't tried it though).
Grtz,
Najrad
Grtz,
Najrad
#249
Grtz,
Najrad
Grtz,
Najrad
#250
I have just tried it and come across one change - I found that my icons were not appearing correctly. Instead of my usual camer gif, there was a default blue circle with a dot in the middle.
Having had a look around - it seems like the size of the gif files in the ICONS/E60 folder has changed to be 28x28 pixels.
b.
b.
