Add a Circuit in Fuse Box HELP!!!!!
Old 02-22-2009, 01:28 PM
zen
zen's Avatar
I did read it carefully. He stated "I do not want to go through the trouble of going straight to the battery and having to turn accessory on and off manually." He was looking for a switched circuit so he would not have to turn it off manually. He was looking for a circuit in the "Glove box". That is why I chose to inform him about the one that I did. I further indicated that it was "always hot". Therefore he has to switch it manualy.
Regards the phone in the glove box. The circuit is always hot. The phone times out (not the circuit) at a predetermined time i.e. one hour. I have my phone set to never time out.
Old 02-22-2009, 02:38 PM
zen
zen's Avatar
NEW IDEA: If you have the flashlight in your glove box, you can buy an adapter that plugs into the socket where the flashlight goes. It has a cigarette type fitting on the other end. It will save you the trouble of wiring. It is however on a timed circuit so you may have to manually turn the device on and off. It is available at the dealer for about $15.00 or from Bavauto.
Old 02-24-2009, 03:43 PM
Longsofty's Avatar
My Ride: 2006 550i
Everyone, we have a winner. The add a circuit works. I used the fuse slot for the CD changer. The beauty of it is that it shuts the unit off when you turn ignition off. The only hiccup was grounding the darn thing in a location that didn't cause noise. It was an awesome $7.99 solution that took about 20 minutes to do. Thanks for everyone's input.
Old 03-17-2009, 07:18 AM
ntpcrew13's Avatar
My Ride: e90 / 330i / arctic / black leather / burl wood trim / steptronic / premium package / cold weather package / navi-idrive / sirius sat radio / 60 gig black video iPod in the aux / bluetooth with iPhone / hard-wired Valentine 1 v1.8 / KW V2 / blacklines / tvandnav2go / half din dvd player / reverse camera / alpine type R 12" sub with RF amp / LED turn signals / bastuck exhaust with SR eisenmann pipes / gruppe M rep intake / 2003 - e53 / x5 / black / black leather / burl wood trim / steptronic / premium package / cold weather package / navigation / 6 disc cd changer / hard-wired Valentine 1 v1.8 2002 - G20 / infiniti / titanium silver / grey leather / automatic / premium package / cold weather package / sports package / 6 disc cd changer / cordless escort solo 2000 - Frontier / nissan / alpine white / grey cloth / automatic / crew cab / white cap
would you mind telling me which fuse slot number that would be?
Old 04-07-2009, 12:10 AM
VirtualRain's Avatar
My Ride: 2006 M5
I also need an ignition switched 12V circuit to power my Laser Interceptor... somewhere in the glove box area.
I tried tapping into the same 12V line that the CDC and Dension (I installed some time ago) use but that seems to be always hot. I guess the Dension is smart and will turn itself off when the bus dictates it. So that won't work since the LI is not on the bus.
What other circuit exists in the glove box area that is switched? The passenger footwell power outlet?
Thanks!
umichchris
12-07-2015 03:33 PM
Maini
08-13-2015 03:40 PM
e60_simr
07-29-2015 02:35 PM
ali-d1936
07-26-2015 05:32 AM
hmilycar
07-07-2015 12:29 PM
Quick Reply: Add a Circuit in Fuse Box HELP!!!!!
