Access to front grill clips
Hey guys
I know a few of you hv successfully replaced your front grill to chromed ones yourselves. I tried to DIY it tonight but finding it next to impossible to reach those top grill clips. My car has those flaps in front, making it even harder. Did u need to take out some other parts in order to gain access? or did u just reach in from the front opening?
I wonder those who had been successful can give me some tips.
Million thx.
Million thx.
My Ride: '04 BMW E60 530d High Executive
My Ride: 2003 X5 3.0----->gone
2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone
2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods...
2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
hey bunbun. Actually for me the hardest part was taking the side grill clips. The top clips for me was the least of my problems. Basically, when you open the hood at the very front, you'll notice some rubber lining, probably for insulating the hood. If you lift that rubber lining, you can see the top grill clips. I used a screwdriver to push down on the clip in order to get it out. Good luck, hope it helps.
If I could do it, you can do it.
There several threads that have done a better job explaining this than me.
Search on this site for these. If not here then section on parts, accessoies, and mods on this same site
Just a few comments or tips to add to more detailed posted instructions.
First they will tell you just to break off the side clips on the grill your taking out because that?s easiest and if you ever want to install the old grills you don?t need them. This true, but you can get them off with out breaking them. Your choice,
The top clips are the easiest. When you open up the hood you will see a 2 inch by the width of the section that goes across the front of the car above the grill area(maybe 40? to 48?). Lift (pinch) up from one of the ends the rubber seal across the width of the top of the where the front grills are. Under that you will see the six easy to reach clips, three each.
You need to take out the lower black grill below where the license plate is to get access to lower clips. It comes out in about three or four pieces. Again search for thread with pict or instructions.
Here?s what I did as I recall. I think I first reached in through the lower grill and popped out the four or six clips, can?t remember how many, lower grill clips. You do this by reaching up through the lower grill opening. It?s good to first look at the clips under the top hood seal to see what the clip assemblies look like so you can see what you need to do to disengage the clips. You can't entirely pop these out yet but you can disengage them and move the out about 1/4 to 1/2 inch.
I then disengaged the upper grill clips. You can?t entirely pop them out yet either but you can move them out about a ? inch so they are no longer engaged. I then went back to going after the side clips, again by reaching up through the lower grill opening. This is not so easy. Find which one to have best reach on. What I did was pull out on the outside of the grill on same side as I working on the clip. Not easy but I was able to pry it off.
Then it was easy. I pulled the grill out from that side from the front slowly and the other side just popped out. While I didn't, if you break the side clips, so what. Its the clips on the one your taking out, and if you want to put them back someday, you don't them anyway.
As to taking out the lower grill I remember having a little confusion at first. I think on the lower vertical members you heed to pinch both sides at the top and bottom of each and they just pull out. These vertical pieces support the horizontal bar.
Again look for better detailed instructions by searching this site. Then just use my tips if they will be useful.
As to putting on chrome strips on your existing grill, the factorylreplacement grill ooks best.
My Ride: In a place where the Mercedes density is the highest in the world (no. of MB per square kilometer) I choose a Bimmer, why? because of one thing "The Ultimate Driving Experience"
My Ride:
523i Steptronic, Silver Grey Exterior, Black Interior with Black Dakota Leather and Maple Wood Trim. Chrome Grill, Style 123 rim, Airbags everywhere, PDC, Rain sensor, Auto lights, Moveable front armrest, Advance Climate Control, Glass Sunroof, Auto dimming interior and exterior mirror with foldable functions, Extended Lights package, 6 CD changer in glove box, Power seats with memory, Power adjustable steering wheel, Power rear sunblinds.
Add ons: 123 wheels, chrome grill, K&N Hi flow filter, Eibach Pro Kit, e60.net decal and 24,000km
Past rides:
2001 Nissan Xterra SE
1999 E39 523i
1999 E46 323i
1996 Acura Integra LS
But Bunbun's car have those cold weather flaps that's in the way so basically you can't reach those bottom and side clips coming up from underneath the grill.
How come Bun Bun has the flaps and you dont? none of the models in the US get the flaps so I dont know...
My Ride: 2004 520i, mystic blue, steptronic, beige leather, pdc, bluetooth, rain sensor, BMW sport kit fitted, 18" 166 rep BMW rims , de-badged, cherished reg. chrome grill,
[snapback]191161[/snapback]
On the grill excellant advice above keep at it is is possible
Thx guys
I'll give it a try again. The flaps came on earlier MY models. I think models post '04 MY dont hv them anymore. I dont even know what purpose the flaps serve.
My Ride:
Past rides:
1999 E39 523i
1999 E46 323i
Those flaps are design for places with extrem cold temperature like Canada or Northern Europe. The car will heat up faster with those flaps but in a place like Hong Kong, it is pointless so I guess they took it out.
My Ride: E60 530i
Engine: M54
Originally Posted by Bunbun' date='Oct 31 2005, 03:27 AM
Thx guys
I'll give it a try again.? The flaps came on earlier MY models.? I think models post '04 MY dont hv them anymore.? I dont even know what purpose the flaps serve.
[snapback]191188[/snapback]
It took me about 30 minutes in the parking lot to remove 2 original grill. You need to be patient. Take it easy and try not to destroy the clips on the original grills.
