AC basic to AC high retrofit DIY rev.3
Old May 9, 2013 | 01:25 AM
  #91
BLooD's Avatar
Originally Posted by tom_il
Same problem.
Setting it to inactive doesn't sounds realy logic. How are you sure its working and not just disabled ?
Because its mis-leading, according to NCS dummy there are two types of AUC, v2 and v4. The LCI panel is looking for v4, so setting it not active is telling the panel you have v2.
Old May 9, 2013 | 01:52 AM
  #92
tom_il's Avatar
My Ride: BMW 525dA 2007 pre-LCI.
Ah ok. I have the pre-LCI panel but connected the LCI AUC sensor.
Would it work then if I set it to not active ?
Old May 9, 2013 | 03:07 AM
  #93
BLooD's Avatar
I have the LCI AUC as well in the LCI position (next to the pollen filter) and set it to not active.
Old May 9, 2013 | 04:28 AM
  #94
tom_il's Avatar
No luck, I don't have AUC_MKIV option in the trc file. I believe I had in the low version reading an old backup file, but not anymore in the high version.
So I added it as night_aktiv and no luck, its there when I read the module but the error 'no signal error from the AUC Sensor' is stil there.
Old May 9, 2013 | 11:40 PM
  #95
BLooD's Avatar
That really odd as the software is the same for both panels just different functions enabled for each panel.
Old May 17, 2013 | 02:11 AM
  #96
bazare's Avatar
I have one question ...
I have a 520d N47 LCI 5er. MY 09/2007
I have installed an LCI IHKA high pannel but after moving all wires from 18pin to 26 pin plug I still have to wires left in the 18 pin plug
pin 2 = yellow red
pin 5 = white green
any advice?
Old May 17, 2013 | 06:06 AM
  #97
bazare's Avatar
seems that N47 diagram is different but in WDS information is incomplete
Old May 17, 2013 | 07:03 AM
  #98
tom_il's Avatar
This thread about the conversion in a pre-LCI.
Old May 17, 2013 | 11:50 PM
  #99
bazare's Avatar
I have managed to make the compressor to work at the moment. There are some differences from the pre LCI wiring. (pin 5 and 8 from x18793)
There is 1 wire red yellow (bigger than the others 0,75 i guess) that i don't know where to put. It's pin 2 from X18793. Some advice please.
L.E.
I did some diagnosis on the car and seems like I have the following 9 errors. Solar and condensation sensor will be installed later.
One question:
rear compartiment flap motor and stratification flap rear compartiment is the same thing? I have 2 errors related to this. The other DTC are normal to be present. And still where should I plug the red yellow wire previously at pin 2?
File Type: pdf
Old May 19, 2013 | 12:25 AM
  #100
BLooD's Avatar
L.E.
One question:
Dont know, your the first person that I know of that's done it on a LCI. Any errors you get for flap motors you should ignore, on the high matrix heater there's 9 motors and on the basic only 6, ignore the heat exchanger temp sensor as well as you only have one temp sensor not two. The error for the ventilation sensor is because on the high heater matrix there's a sensor down wind in the centre dashboard vent, this can be fitted if you wish.
