about logic 7
My Ride: bmw 530d,2004,500nm,navi profesional.bi-xenon ,adaptive curve light,active sterring,etc...
my car has standard audio sistem(not Hi-FI) I have only 4 spekers and 2 subs under setat,in while i update whit Sws subs,andd now i want to retrofit to L7,someone doo that ?
i need some advices,thank in advance
i have here all L7 speakers ,excluding Subs
thank again
thank again
You'll need Vehicle Order to include L7 option.
Dealer need to perform hardware installation and software retrofit.
Hardware needed:
L7 amp + MOST optical cable if not prewired
New two rear door panels to accomodate two 4" mid-range speakers
All L7 speakers
CD changer
and the most important thing... lots and lots of cash
Hardware needed:
All L7 speakers
CD changer
Originally Posted by 525iSE' post='377110' date='Jan 11 2007, 11:55 PM
New dash as well right? Because you have to fit a center speaker in there too if I remember correctly.
i have all parts ,what i need whiring shematic,and amp schematic
have you received any schematics yet, please? I'm interrested in it as well. I do have Business Navigation with the stereo sound system, and I would like to add some speakers and a amplifier as well. I do not want to connect the amp to speaker output, but I'd rather have it connected to the line-out of the car stereo.
Thanks,
Ajo
Originally Posted by ajo' post='429821' date='May 30 2007, 01:33 PM
Hello,
Thanks,
Ajo
Thanks,
Ajo
I can't see, why programming of the CCC should be a problem...
Originally Posted by Dirk' post='430350' date='May 31 2007, 09:20 PM
I had an L7 Amp in my hands myself. However, I did not feel comfortable to cut the MOST-Fibre in the trunk. You'll also need all the wiring from the trunk to doors, etc. Shouldn't be there if you have standard audio. I guess it is somehow demanding but as far as I know, you would be the first how did it in this forum
Here is a link with some infos to start with, and I have also the schematics from WDS (CCC and L7 amplifier) MOST connection is necessary.
It is the only way to transfer signals from L7 amplifier to CCC and opposite.
Here and here some infos too.
My Ride: 2006 525i, Premium,Cold,Xenon Packages
Originally Posted by nicke60gre' post='430362' date='May 31 2007, 01:49 PM
I have all the parts too (L7 amplifier and all the L7 speakers) and I will retrofit it over my standard audio. To much work, I know, but it has to be installed
Originally Posted by coolguy' post='430378' date='May 31 2007, 10:42 PM
I think you will have like a Paragraph of Mods in your signature soon
I have an OEM HUD kit also waiting for a dash
Any update on this? Can this be achieved?
