A 530i Oil change question
Old 07-22-2009, 09:55 PM
bmdavid79's Avatar
My Ride: 2004 545i
I have a 2004 545, I was wondering where is the dipstick located or if it even has one. I am thinking about doing my on diy on the oil change. Thanks
Old 07-23-2009, 06:52 AM
kaiten408's Avatar
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
Originally Posted by Raheel312' post='948745' date='Jul 21 2009, 07:33 AM
On my 04, I use a 36mm socket to remove the oil filter cap, and to tighten it I believe it's 25 lbs.. I'm not too sure, but it says it on the filter cap itself. You'll need a 17mm for the drain plug.
36mm socket? That's wierd my '05 used a 24mm socket for the oil filter housing
Also, it's not 25 lb. ft. the housing says 25 nm. which translated to lb. ft. is ~18 lb. ft.
Old 07-23-2009, 07:20 AM
txag_530i's Avatar
How do you all get away with not using the special oil filter housing removal tool? My filter housing is a lot bigger then 36 mm (1.4 ").
txag_530i's Avatar
Yes, the V8's still have dipsticks.
Look here for some guidance on the V8 oil change-
550i oil change
socale39
09-05-2023 08:30 AM
Steven06
04-08-2015 12:32 PM
Boland01
04-06-2015 10:25 PM
mantraguy
03-09-2015 02:56 AM
Don Juan
03-11-2004 03:14 PM
Quick Reply: A 530i Oil change question
