A 530i Oil change question
Old Jul 16, 2009 | 05:33 AM
alpina04's Avatar
Thumbs up
What size socket do i need to remove oil filter cap?
How many ft lbs torque is needed to tighten?
Old Jul 16, 2009 | 06:01 AM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
Sorry I don't know the specifics to your questions.
This is what I use. Put a rag around the cap so it doesn't get scratched.
Be sure and change the orings then tighten the cap by hand till it won't turn any more.
Start the engine and check for leaks.
FYI: the oil comes out of the crankcase with a fury! I read on here about fabricating a deflector
out of aluminum foil. It worked for me and spared a huge mess.
Old Jul 16, 2009 | 06:05 AM
pjinca's Avatar
+1 Be vary careful, I had to clean up that huge mess (I didn't read the DIY's before hand, figured I have been changing my oil for 20 years). Be careful with the oil filter cap, it's plastic and will scratch easily and DEFINITELY set up a funnel or other barrier to keep the oil going where you want it to when it drains.
Old Jul 16, 2009 | 06:28 AM
530inOK's Avatar
My Ride: 540i
Model Year: 2017
Would it have been too much trouble putting the drain out the bottom of the pan instead of the side?
Working on cars should be a prerequisite to designing them. IMO
Old Jul 16, 2009 | 06:32 AM
pjinca's Avatar
+1 Whole heartedly agree with you there. Have you SEEN the crazy places some designer put the oil filter? And don't get me started on spark plug placement, eeesh!!! It's like they WANT you to bust every knuckle.
Old Jul 16, 2009 | 06:39 AM
theXman's Avatar
My Ride: 2004 530i
I think they don't want you to do DIY but bring to the dealer so they can charge you an arm and a leg for it.
Old Jul 16, 2009 | 06:46 AM
pjinca's Avatar
Ah, so the thoughtless design was intentional, it all makes sense now...............
Old Jul 16, 2009 | 07:45 PM
kaiten408's Avatar
My Ride: I have an 05 545i. It's a manual with a few options. This is my first BMW but I don't know how I'll ever be able to switch to something else.
Oil filter cap is 24mm socket. Tighten it to ~18 ft. lb. torque
Old Jul 20, 2009 | 11:03 AM
alpina04's Avatar
Thx guys for ur lovely input. I was luck and didnt have the massive oil spill. I did find the 36mm socket fits lovely.
Old Jul 21, 2009 | 04:33 AM
Raheel312's Avatar
On my 04, I use a 36mm socket to remove the oil filter cap, and to tighten it I believe it's 25 lbs.. I'm not too sure, but it says it on the filter cap itself. You'll need a 17mm for the drain plug.
