2008 535i Oil Filter Housing Gasket(s) Replacement Help
Does anyone have the part number for the O-rings that go on the oil lines coming from the oil cooler (the lines plug into the ports on the bottom of the oil thermostat housing; clearly shown in the DIY write up by tonyb635)
My Ride: 2008 528i
Just a quick thank you for the links and encouragement to try this DIY.
This was an easy way to save money and get to know your vehicle.
I would highly recommend completing this repair yourself. MY only thoughts were:
1) Drain some coolant... This was my biggest mistake,
2) Get a ratcheting 12 point wrench set,
3) Do an oil change at the same time,
No more than an 1 of work, even with the oil change.
mantraguy
03-09-2015 02:56 AM
