2008 528Xi
Engine: N54
1) Order the SAT module and a mounting bracket if needed
2) Plug in the MOST/power adapter
3) plug in the aerial
4) Pay your dealer $50-$75 - hopefully to code the car to recognize the SAT.
I actually have a SAT module sitting on my work bench I think. Get a quote for what you will pay to buy a new one and I will sell you my used one for half that. I will plug it into my car to confirm that it works.
PM me if you are interested.
See this thread for related how-to info: https://5series.net/forums/topic/532...e-install-diy/
My Ride: 2012 535i M-Sport
For me, installing bracket and plugging the unit in was only half the battle. The MOST hub also there in the trunk required some re-routing since SIRIUS is by default 'out of the loop'. There is an official PDF on this that I am currently unable to locate - ask your parts guys, they can print it out.
Engine: N54
Engine: N54
I still have the unit.
It is 65129119346 found here: http://www.realoem.com/bmw/showparts...=65&fg=05&hl=9 Of course it shows there are newer models that replace this one but I checked my usual supplier and couldn't find any of them.
This came out of my 2007 530xi which I bought CPO. The module casing had some surface rust on it and when I complained that I was "worried" about it the dealer replaced it. Before it was replaced, I used it for a couple months with my Sirius subscription so there is nothing wrong with it.
You don't have enough posts for PMs to work yet.
Jim
PelicanParts.com
07-23-2015 12:29 PM
