Visor vinyl removal mess up
My Ride: BMW 545i, SilverGray with 30% tint all around
I had read a couple of forums to use acetone to remove the visor vinyl decals. Well i did and it has left black stains on the visor. What can I do to get rid of this black spot. Better question, is there anything i can do before i replace it?? thanks for the advice in advance
try checking with window tinting shops. My tinting place used some spray thing to remove the decal stains on the windshield. I dono if its the same for the visor. Maybe they'll have a solution for you.
My Ride: 07 530i|Silver Gray/Black| Premium|Sport|NAV|Auto|PDC|Sunshade|
If you are referring to the sticky residue left after removing the decal, using lighter fluid will remove that completely. I have used lighter fluid to remove window glazing which is super sticky. Window glazing is use for duel pane windows to adhere to the window frame.
I would take a towel and pour a little of lighter fluid on it and gently try to rub it off. make sure the doors are all open to allow for ventilation.
My Ride: '04 530i Mystic Blue, European Delivery, Steptronic, Prem Pkg, Cold Weather Pkg, Nav, Heads Up, Active Cruise, Rear Sunshade, Rear Side Airbags, Rear Seat Heating, Park Distance Control, Xenon, CPT9000 GSM phone, red rear reflectors, Sirius!!!!
I had great success using a product called Goo Gone for the same problem you have described.
Originally Posted by Bigfoot' post='367059' date='Dec 13 2006, 04:32 PM
Anyone else have any suggestions?? If not, does anyone know how much a sun visor costs and where i can get one?
Try applying WD 40 to the visor.
I would remove the visor from the car and do it where you wont get these cleaners/solvents on your seats, dash, or carpets.
I successfully removed the sticker using acetone from the visor, but the thing is that there is a big black stain in place of the sticker. Im gonna try a few of the aforementioned techniques. thanks for the advice guys, hopefully one of them will work.
The link you posted doesnt work. If you can send it again i would appreciate it. Thanks once again.
Originally Posted by MAK' post='367063' date='Dec 13 2006, 03:48 PM
Try below it will give you an idea of cost of a new one.
http://www.realoem.com/bmw/select.do
My Ride: 535ixT � On Order: 2010 E61, Ordered 1/05, Est. Birth 3/09, Est. Delivery 4/09, Carbon Black, Cream Beige Dakota Leather, Steptronic, M-Sport Pkg., Type 135 18
Model Year: 2010
