5Series.net - Forums
-   Detailing Forum (https://5series.net/forums/detailing-forum-15/)
-   -   Visor vinyl removal mess up (https://5series.net/forums/detailing-forum-15/visor-vinyl-removal-mess-up-34477/)
Bigfoot Dec 12, 2006 08:20 PM
I had read a couple of forums to use acetone to remove the visor vinyl decals. Well i did and it has left black stains on the visor. What can I do to get rid of this black spot. Better question, is there anything i can do before i replace it?? thanks for the advice in advance
525iSE Dec 13, 2006 06:11 AM
try checking with window tinting shops. My tinting place used some spray thing to remove the decal stains on the windshield. I dono if its the same for the visor. Maybe they'll have a solution for you. :thumbsup:
Bigfoot Dec 13, 2006 11:32 AM
Anyone else have any suggestions?? If not, does anyone know how much a sun visor costs and where i can get one?
MAK Dec 13, 2006 11:48 AM
Try below it will give you an idea of cost of a new one.
http://www.realoem.com/bmw/select.do
low_ball_88 Dec 13, 2006 12:30 PM
If you are referring to the sticky residue left after removing the decal, using lighter fluid will remove that completely. I have used lighter fluid to remove window glazing which is super sticky. Window glazing is use for duel pane windows to adhere to the window frame.
I would take a towel and pour a little of lighter fluid on it and gently try to rub it off. make sure the doors are all open to allow for ventilation.
NC530i Dec 13, 2006 12:42 PM
I had great success using a product called Goo Gone for the same problem you have described.
Veight Dec 13, 2006 01:31 PM
Try applying WD 40 to the visor.
I would remove the visor from the car and do it where you wont get these cleaners/solvents on your seats, dash, or carpets.
Bigfoot Dec 13, 2006 02:31 PM
I successfully removed the sticker using acetone from the visor, but the thing is that there is a big black stain in place of the sticker. Im gonna try a few of the aforementioned techniques. thanks for the advice guys, hopefully one of them will work.
The link you posted doesnt work. If you can send it again i would appreciate it. Thanks once again.
Hopco Dec 13, 2006 03:00 PM
Bigfoot
The Real OEM link seems broken for now.
Bigfoot Dec 13, 2006 10:21 PM
thanks Hopco, finally found the sun visor, but i gotta try gettin the stain out before i spend 200 on a new one.
