I'm exploring orbital polishers, and came across the "Ultimate Detailing Machine" sold on Autogeek.net.
http://www.autogeek.net/ultimate-detailing...a-polisher.html Is anyone familiar with it and know how it compares to the Porter Cable or Griot orbitals? Thanks, Lou |
Have you checked out Autoia's UDM Forum? Generally very good reviews for it there.
If I was starting fresh on purchasing detailing equipment (I have the Griot's random orbital and a rotary), I would seriously consider the UDM. WARNING: Once you start down the path of polishing you own E60i, it can never been shiny enough ... talk about an addiction. :wacko: |
Interestingly, Zaino doesn't recommend using orbitals. http://www.zainostore.com/Merchant2/mercha...e=Z#anchor37123 I don't recommend it because you waste too much polish that way. The pad on an eleven inch polisher can absorb almost enough polish to coat your entire vehicle. Each time you use an orbital to apply Zaino polish, you are probably wasting as much polish, if not more than you actually applied to the car. Zaino polish applies easily by hand, especially if you dampen the applicator pad with water and spritz it with Z-6 before applying it. |
UDMS have more power, less vibration than the PC. However there is a version 2 of the UDM that should be coming out soon.
I am using it and think it's pretty good. (apart from the too easily caught "on" switch)
Can't comment about the Porter in comparison, as the UDM is the first machine I've used |
