Remove Tires to Clean?
Old Apr 1, 2007 | 01:46 PM
marknorrell's Avatar
My Ride: 2006 530xi => Silver-Gray with Beige Dakota leather; Auto, Premium, Cold, Comfort Access. Other: 1998 MB 320E and 1990 MB E300
Today I was hoping to remove my tires, one-at-a-time, to more easily clean the inside surfaces. The winter weather left a lot of tar and brake dust specks.
However, when I got the car jacked up and lug bolts removed, the tire wouldn't come off.
I looked to the owner's manual for help, thinking there was a trick to it. However, the instructions say, "Don't do it yourself; have authorized service do it".
Does anyone have any advice? (Besides "Buddy your obsessed!" )
Mark in Kansas
Old Apr 1, 2007 | 02:02 PM
aR.'s Avatar
aR.
It is Normal that the wheels won't come-off if they have been on for a while - they alomost feel like as they are locked and stuck! Just use both hands across and use to rock it back and forth slowly and with minor jerking motion and you will notice that they start to loosen up and and will come off one by one. You may have to use a rubber mellet (or really your feet also) on the inside or to the outside as an "encouragment" once in a while to release these if they are stuck- It is very common way of doing it. Be careful not to apply too much force to have the car drop from the floor jack, etc.
Goo Luck...Happy Cleaning...
Old Apr 1, 2007 | 02:37 PM
E60M5E60's Avatar
Use a rubber mallet as aR said. They rotor surface is getting a little rusty and the wheels stuck. To avoid this problem in the future use some antisize compound on the rotor surface where the wheel goes and the next time the wheels will come off very easy. Be carefull not to put any antisize compound on the rest of the rotor.
Old Apr 4, 2007 | 11:52 AM
diveleader's Avatar
My Ride: 545i SE Oct 03 (53 plate) 19" Alpina Classic rims
Just tap it with a rubber mallet - direct on to the tyre wall. this should gradually loosen the wheel. I would recommend that the you try this with the wheel just off the ground. This should reduce the ' rocking ' that you will get if the jack is higher.
Old Apr 5, 2007 | 08:54 AM
russo's Avatar
My Ride: E46 320i, M3 paddle shift, Sat Nav
Why don't you just use a stick and a sponge to reach the inner wheel well? Save all the trouble. Don't be a nut to remove all the nuts.
Old Apr 5, 2007 | 09:12 AM
spider991's Avatar
I clean my wheels using a special brush from the car parts stores but the dust speckles still build up, the only way to remove them is to take the wheels off, use a alloy wheel cleaner then finish by polishing them inside and out. The wheels give a nice shine again
Nihilation
Jul 10, 2022 11:32 AM
RobR
Jun 2, 2015 08:31 AM
TexaZ3
May 6, 2015 09:54 AM
Stranger12
Apr 12, 2015 02:07 PM
crazy bimmer
Mar 20, 2015 07:42 AM
