PS Detailed: 1987 Black Ferrari 328 GTS and a 1972 Red Ferrari 365GTC/
Old Oct 16, 2009 | 04:39 AM
gmblack3's Avatar
My Ride: 99 740il and 2008 GMC Denali 1500
Just a little road trip down to Montgomery, AL for these two horses.
Both cars where paint only details.
First up is a 1987 Black Ferrari 328 GTS single stage original paint.
Client was kind enough to have the car washed for me and elected just to have a one-step polishing done.
Before pics:
Process:
Z6 wipedown
Zaino clay w/ Z6 as a lube.
White LC classic flat pad/M205/PCXP6 via KBM
This process was working great. I was amazed at the amount of defects that where bring removed. This is the rear deck area after the one-step polishing:
But unfortunately I only had 5 white pads with me. The single stage paint was clogging up the pores of the pads at a very fast rate. I tried to brush them off, but I could not maintain a good level of cut. So I started washing the white pads with APC and warm water in the sink. This is my usual method of washing pads during the KBM. I spin them out with a rotary.
I set up my air movers to dry the white pads. When using the KBM is very important that you use pads that are very close to 100% dry. If not the water in the pad will cause the non diminishing abrasives to clump together which will cause excessive micro marring.
An hour later I went to use one of the white pads that should of been dry by now. The white pads are made from a higher blend of non-reticulated or closed cell foams which does not lead to fast drying times. The white pad was not dry enough. So I had to go another route.
I have plenty of classic orange flat LC pads, so I used the following:
Orange/M205/PCXP6 via KBM
This left some surface marring so I followed with:
Black/M205/PCXP6 via KBM
So much for the one step polishing.....
The nice thing about M205 is the minimal amount of dust vs M105 on some paints.
I still did a QEW wash follwed by a Z6 wipedown to prep the surface the best I could for the Z5pro.
Applied 2x of ZFX'd Z5pro, followed by Z8.
After pics:
Old Oct 16, 2009 | 04:40 AM
gmblack3's Avatar
1972 365GTC/4
Repainted with a clearcoat.
Paint only detail, 2 step polishing with a minimum 85% defect removal.
QEW to remove the dust.
Clay
M105/Orange LC flat/PC6 via KBM
M205/Black LC flat/PC6 via KBM
IPA wipdown
Z6 wipedown
Z5pro x2
Z8
Before:
dsummersm3
Nov 14, 2019 07:50 AM
ArnottInc
May 11, 2015 11:56 AM
TexaZ3
May 6, 2015 09:54 AM
TroyE60
Apr 14, 2015 06:30 PM
ArnottInc
Apr 2, 2015 10:46 AM
