Foam Cannons ?
Old 11-26-2007 | 04:08 PM
westcoast550's Avatar
I see more info coming out about foam cannons for washing your car, it looks like a good idea , any thoughts from users ? Which ones would you recommend and what are the best ways to use them ??
Thanks and Cheers
Old 11-26-2007 | 04:22 PM
vafinest25's Avatar
My Ride: Expected delivery on 15 Jan 2007 525I Olivian Green, Beige Interior, PP, CWP, PDC, SP, Rear shades,heated rear seats, Ipod fitted, Nav, Oem Rims 166, Xenon Lights, Wood grain package, illuminated door sills
Alot of people are starting to use them more and more, I just bought one from autogeek.net, and C, and Fminus use them to do their cars. you should check out Fminus's work on this site under detailing he has probably the most experience with the foam cannons. I will be getting mine tommorow and plan to use it on my 5 and my Yukon. Will post pics...Hope this helps.
Old 11-26-2007 | 04:28 PM
Thanks V , looking forward to your comments .............
Cheers
Old 11-26-2007 | 06:32 PM
BMWSTL's Avatar
My Ride: 2008 550i ZSP with Style 167 wheels
FYI, the quart Foamaster Foam Gun is on sale at Autogeek ($10 off; I believe through 12/3):
Foam Gun Link
DP Xtreme Foam is also on sale (-$5 32 oz., -$10 128 oz.):
DP Xtreme Foam link
And, you get $10 off your next order. If you buy $75, input "AGO" in the code field for free shipping. Pretty good deal.
Lou
Old 11-26-2007 | 06:34 PM
C's Bimmer's Avatar
Autogeek. Get the Quart size one. I also got a big gallon of the DP Foaming Shampoo. Happy Foam Cannoning!
Old 11-27-2007 | 06:36 AM
keith84_uk's Avatar
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED) Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
This is the 2nd Gen of gilmour foam gun which i have got:
http://www.cleanyourcar.co.uk/washing-dryi...i/prod_329.html
And this is how it would look like:
Source from: www.detailingworld.co.uk
Pro-detailers use it for pre-soak the car (Not wash the car) which soften the surface dirt and grime first, but it still need to wash it with two buckets method if you want a swirls free car.
Most pros prefer foam lance (Work with pressure jet) rather than this foam gun (Work with hose) as the foams from foam lance will stay on the car much much longer!
Keith
Old 11-27-2007 | 06:59 AM
I'm going to order the one from Autogeek , do you spray the car down first or apply the foam dry ??
Cheers
Old 11-27-2007 | 07:49 AM
keith84_uk's Avatar
spray the car down first will be the best and wont be a much difference on the foam holding ability
And remember the "right" shampoo is the key to produce large amount of foams e.g CG Maxi Suds II,Megs Hyper wash or as BMWSTL recommed you the DP Xtreme Foam........
Normally i fill 1/4 shampoo and 3/4 bottle of warm water and this should gives u pretty good result!
Goodluck!
Keith
Old 11-27-2007 | 08:32 AM
C's Bimmer's Avatar
Cheers
Here's what I do when washing:
1) Rinse car
2) Foam car - allow to soak in.
3) Rinse car
4) Wash car with 2 buckets (one with your soapy water and one with your clean water to clean your mitts before going back in for more soap in the other bucket).
5) Rinse car
6) Dry car with microfiber towels
7) Get out Leaf Blower and blow every drop out of every crack.
8) Dry again
9) Spray car with Z6 Detail Spray or Z8 Grand Finale Spray
Done!
Old 11-27-2007 | 08:36 AM
1) Rinse car
3) Rinse car
5) Rinse car
8) Dry again
Done!
Thanks C
Cheers
Quick Reply: Foam Cannons ?
