Buff Buff Buff away!
Whenever i apply Zymol (ahh the beach) or Meguiers Tech Wax to the bonnet (hood) or boot (trunk) i find it increadibly difficult to buff off without it leaving what can only be described as 'streakyness'.
In the light i can see bits that havnt buffed off properly.
To combat this I buff as much as my arms will take and then spray on some Meguiers nxt wax which rubs off quite easily and leaves no 'mess' behind.
Am i missing something (bar a polisher) or is this the same for everyone?
Car is cool/cold when I wax and i follow all the instructions properly. I use the proper applicator and proper cotton towel for rubbing off too...
Banned
I used Zymol for many years, but got tired of the difficult application/removal process, and lack of durability, so a few years ago I switched to One Grand Blitz wax. High quality carnauba, easy on/off (apply to entire car, then buff off!), and great durability for a carnauba. I do miss the coconut smell, though!!
After years of experimenting, I found the best results with Zymol are obtained by applying as thin a coat as possible with a closed cell foam pad (I used the Zymol pad) to a 2" x 2" section max, and buff off before it dries using a microfiber towel. The microfiber towel makes a big difference--give that a try. Or better, switch to Blitz! Are you using Zymol Creame or Carbon (carbon is for dark cars)?
Yeah, I have to do the buff, buff, buff ting - what I found that works is multiple rags - I start withone - buff lightly - no pressure but a lot of buffing, then switch to another clean rag, then another - it works
lots of time, but since no pressure minial effort
My Ride: E46 320i, M3 paddle shift, Sat Nav
There is bound to have some streaks left on the paintwork if its not buffed properly. For me to be sure I would use a quick detailer or Zymol field glaze to go over it with a microfiber cloth. That should do the trick. Try it.
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
