BIG "A" DETAILING Queens NY (718)445-9995
2009 Nissan 370Z Montery Blue
hand washed, leaf blower & absorber to dry
blue fine grade clay magic surface preparation bar
70% Isopropyl Alcohol
to clean the wheel lips, bottom of rocker panels, bottom of bumpers
free of road tar & other heavy road grime
#000 steel wool
to polish all glass free of bug splatter & to polish exhaust tip
3M Plastic Cleaner
to polish head & tail lights free of bug splatter
RejeX
applied to head & tail lights, all glass, exhaust tips, wheels
Smart Detail
misted on the car before polishing
3M 3/4" green tape to mask off rubber moldings
Flex XC 3401 with a 6.5" blue DD pad
3M Perfect-It Ultrafine Machine Polish
1Z Einszett Glanz Wax applied by hand to seal
Lusso Oro Wax applied by hand as a top coat
Smart Dressing
for the tires
Black WOW Exterior Trim Restorer
for the rear trunk glass molding that was dull, dry & discolored
applied with a qtip
Black WOW
#000 steel wool
3M Plastic Cleaner
RejeX
Smart Detail
Smart Dressing
for the tires
applied with a qtip
Black WOW
RejeX
applied & left to cure
after the car was finished being polished, sealed & waxed we then removed the RejeX
some final shots
hood
drivers side
right tail light & quarter panel
the back of the Z is so wide & sexy, i love it!
some final shots
hood
drivers side
Very nice work Andrew, good luck, looks like you do a fantastic job.
BTW, what is Rejex? Can it be used on the windows, plastic, and wheels?
RejeX was originally developed for the Air Force to keep turbine exhaust gas residue from sticking to aircraft...
RejeX is a thin-film polymer coating designed to provide a high-release surface. This very thin film - less than a micron thick - prevents stains and adhesion of common contaminants such as exhaust, bugs, oil, tree sap, bird droppings, road grime, brake dust, etc. It also makes graffiti easy to remove and can be applied to windshields to repel rain. It's easy to apply and produces a deep, lustrous shine that outlasts the most popular waxes by months.
RejeX contains none of the free silicone oils found in some other products that are known to contaminate paint and cause problems when repainting.
Protects and beautifies painted metal, glass, acrylic, gel coat, fiberglass, glossy plastic and polished metal surfaces.
RejeX is not meant to be used on porous surfaces, highly oxidized painted surfaces, or to fill fine scratches. RejeX can be used over existing wax; however, the duration of protection will be reduced as the softer underlying wax degrades comparatively quickly. There is no reason to wax over RejeX. RejeX leaves a shinier, longer-lasting finish than wax? and the wax can't adhere well to RejeX!
REJEX EARNED MIXED REVIEWS FOR IT'S DURABILITY ON PAINT. IT'S RECOMMENDED FOR USE ON GLASS & PLASTIC AS A WATER REPELLENT & AS A WHEEL SEALANT TO HELP KEEP A HEAVY BRAKE DUST BUILDUP FROM FORMING.
Great info about Rejex, thanks for sharing for those of us who can;t exactly "drop by" or I would drop my car off (3000+ miles is a ways to go though )
bestofthebest
03-28-2016 02:47 PM
DetailersDomain
Detailing Forum
09-22-2015 03:59 PM
capn
Meet & Greet Discussion
09-21-2015 08:55 PM
DetailersDomain
Detailing Forum
09-03-2015 07:08 PM
