Tire Shop in Northern Virginia
Can anyone recommend a tire shop in Northern Virginia (near Fairfax, Mclean and Arlington)?
I am considering of putting on winter tires for my car but feel a bit concern if the tire shop can handle run-flat tires.
Thank you,
Josh
Thank you,
Josh
My Ride: 2015 535D M Sport
COSTCO
http://www.costco.com/Warehouse/locator.as...&lang=en-US
Best price for Michelins. They replaced my runflats with non-runflats. They have equipment to handle them at most stores. Call to confirm.
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Thank you,
Josh
Thank you,
Josh
I am friends with the owner of a shop called Intersport Performance - he specializes in German cars, they race-prep Porsches, do a ton of HBL's farmed out stuff, etc... He is in Tysons. His shop is one of the few that will do a real alignment too - I have seen them spend hours on an alignment. I don't know for sure about the runflats, but I would imagine that he must be equipped to handle them.
This is the address - 1524 Springhill Road McLean, VA 22102
My Ride: 2008 535Xi
2006 X3, wife's car
Thank you,
Josh
Thank you,
Josh
If you just need installation of tires you already own, you might try looking up recommended installers on the Tirerack web page.
If you need to buy the tires and have them installed, then I recommend you consider buying from Tirerack, and having the tires shipped directly to one of their recommended installers.
For my zip code, I found Tirerack recommendations had an "upper tier" called Price Pledge Plus Recommended Installers, and a "second tier" called All Other Available Recommended Installers. I recently purchased a set of tires from Tirerack and had them installed on my wife's X3 using one of their upper tier recommendations (Royal Service in Alexandria). They did an excellent job.
Thanks
Bruce
I think most shops can do run flats at this point. The main thing is to watch them do it. I can't believe how lame many shops are.
Two case in point...
I was at the local NTW one time for one of the cars. Watching the guy dismount old and mount the new tires. When it came to balancing, he would put it on the spin balance machine and let it run. Tack a weight at the right spot. Then spin the tire again. On that second spin, when it didn't come up as balanced, he removed the first weight and started over!! Obviously, no one had ever trained the guy or checked up on his progress. I wanted him do this three times in a row and then I couldn't help myself. He spoke little English, but I motioned to him to not take the weight off and put another on one and then presto - on the third spin, it was balanced. Big simile from him at that point. But, how many tires had he balanced before that which didn't go out the door correct?
Another time I had a "disagreement" with the manager of a local tire place about mounting the tire so the lighter dot lines up close to the valve stem. They guy told me I had no idea what I was talking about. This is the manager!
I can go on with incompetent and lazy mechanics. The main thing is not get get bamboozled and watch what they do.
sweetnlowe60
04-07-2015 01:23 PM
