New MP3 Service Bulletin & CD/CDC Mute Bulletin
Full text and PDFs
In another thread someone pointed to E90 forum where I found that new bulletin had just been released thanks to dgjk for the link.
SI B65 30 05
Sound System, Cruise, Alarms, Monitors January 2006
Technical Service
SUBJECT
CCC: MP3 CD Playback Not Available
MODEL
E60, E61 (5 Series) with SA 609 CCC-Navigation from 3/05 to 9/29/05 vehicle production
E63, E64 (6 Series) from 3/05 to 9/29/05 vehicle production
E90, E91 (3 series)) with SA 609 CCC-Navigation vehicles produced up to 9/29/05
SITUATION
The MP3 option is not available in the audio menu. When an MP3 CD is used, it is not recognized as a valid CD.
CAUSE
The stability of earlier CCC (Car Communication Computer) software did not allow for proper MP3 functionality.
PROCEDURE
On a customer complaint basis only, retrofit MP3 functionality using Progman V20.00 or higher.
Refer to the SI B09 05 01 Coding, Individualization, Programming (CIP), for the "Retrofit" procedure.
Select "MP3" from the retrofit list and follow the on screen instructions for retrofitting MP3 capability.
The service code "KMP3" will be added to the end of the vehicle order as displayed in the Measures Plan.
After the procedure is complete, turn the ignition off and wait 5 minutes or until the driver's switch block LED goes out. Check the functionality of the system.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
65 83 94 23 00
Labor Operation:
Retrofit MP3 (programming/coding performed as part of a Technical Campaign)
Labor Operation
Labor Allowance
+00 56 743
4 FRU (E60, E61, E91)
3 FRU (M5, E63, E64, E90)
Labor Operation:
Retrofit MP3
Labor Operation
Labor Allowance
00 56 110
10 FRU (E60, E61, E91)
9 FRU (M5, E63, E64, E90)
+00 56 744
8 FRU (E60, E61, E91)
7 FRU (M5, E63, E64, E90)
Labor Operation:
Retrofit MP3 and program/code control modules
Labor Operation
Labor Allowance
00 56 111
16 FRU (E60, E61, E91)
15 FRU (M5, E63, E64, E90)
+00 56 745
15 FRU (E60, E61, E91)
14 FRU (M5, E63, E64, E90)
Labor Operation:
modules (including CAS)
Labor Operation
Labor Allowance
00 56 112
17 FRU (E60, E61, E91)
16 FRU (M5, E63, E64, E90)
+00 56 746
Note: Should the vehicle be affected at the same time by another repair in which programming of control units is also required, programming may be claimed only once.
Note: The following explanations will spell out the correct use of the work times.
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment.
__________________________________________________ ______________
SI B 65 32 05
Technical Service
SUBJECT
CCC: CD/CDC Track Counter Advances After Mute Selected
MODEL
E90, E91 (3 Series) with SA 609 CCC-Navigation
E63, E64 (6 Series)
SITUATION
One or more of the following situations can occur since the vehicle software was updated with CIP 16.1, while the customer is listening to an audio CD in the CCC (Car Communication Computer) or the CDC (CD Changer):
The customer presses the rotary knob to mute the audio and turns the controller to highlight the next track, the track counter starts to advance.
The customer presses the rotary knob to mute the audio and turns the ignition off. The vehicle enters sleep mode and then the customer turns the ignition back on, the audio is still muted but the track counter is advancing.
CAUSE
CCC software error
PROCEDURE
Do not replace any parts.
Once a software solution is available this service information will be updated.
For Information only
SI B65 30 05
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
PROCEDURE
Defect Code
65 83 94 23 00
Labor Operation:
Labor Operation
Labor Allowance
+00 56 743
Labor Operation:
Retrofit MP3
Labor Operation
Labor Allowance
00 56 110
+00 56 744
Labor Operation:
Labor Operation
Labor Allowance
00 56 111
+00 56 745
Labor Operation:
Labor Operation
Labor Allowance
00 56 112
+00 56 746
Main Work:
OR
+Associated Work:
SI B 65 32 05
Technical Service
SUBJECT
MODEL
E63, E64 (6 Series)
SITUATION
CAUSE
CCC software error
PROCEDURE
Thanks cd. Here's hoping my 545i, purchased in June 2005, was made "from 3/05." How can I find out the build date of my car? Thanks again.
Originally Posted by Bobbin-Man' post='224679' date='Jan 15 2006, 03:44 PM
And for '06 cars without Nav? ![Think](https://5series.net/forums/images/smilies/imported/think.gif)
i think we have prof radio standard though
My Ride: 530i 6 speed
Originally Posted by E60Sim' post='224670' date='Jan 15 2006, 03:29 PM
What about us with the 2004 cars with CCC ?? We will just have to wait and wait....
Seemed very complicated and these are the type of things I do that always get me into trouble - so I would wait until monday and call the dealer with your vin and they can give you the production date.
If you are bored do a search of build date and sift through the posts and you will find the instructions
Can not cut and paste at teh somputer I am on or I would attach them - sorry
My Ride: in 2005... a completly crashed Audi A4 3.0 Quattro.
... 24th Jan. 2006... a new 530xd Touring
06 without nav in the us works fine
[/quote]
WONDERFUL...!!!
I will receive my E61 with Prof Radio (European model) in 3-4 weeks....
So, normally, I (it...) should be able to manage the MP3 format.
Just one question... Do I have to ask for a software upgrade or will it be done directly through a "factory" setup????
The worst thing in this.... is that I asked this question to BMW one month ago... and no one was not able to answer me... !!!
They maybe should be more professional and get a subscription to this forum......
[/quote]
WONDERFUL...!!!
![Innocent](https://5series.net/forums/images/smilies/imported/innocent.gif)
