Extended Warranty
I am about to purchase the AUL Reserve Policy (5yrs/100k miles) for $2750. Anyone had a good/bad experience with this company?
Also, the best quote I've had for the extended maint is $1900...anyone know where to get a better deal?
Thanks!
Thanks!
Thanks!
Thanks!
Do a search here. You should save about $500.
On the warranties, you are about $1000 to $1300 too high with zero deduct--if your car is still in factory warranty.
Toyota, Honda, GMPP, Fidelity, etc. Lots of info here if you search for it.
Is AUL inclusionary or exclusionary? That makes a hugh difference coverage for expensive parts.
Thanks!
Thanks!
I am paranoid about their website. It does not show the actual policy. The PDF file is just a repeat of the first page of website. It then goes on to ask you to sign an agreement WITHOUT showing you the actual document. Also asks you to waive a loaner. hmmm. Wording on website does not specify type of policy, exclusionary or inclusionary.
Have you googled for 'problems with...?'
It is exclusionary...supposedly the best coverage available...
