Extended Maintenance or not
Hi guys:
My current free maintenance on 04 545i expires end of June. Yesterday, I took my car to the dealer for vehicle check, and had them change the engine oil, all fluid, all brake pads. Should I still buy the extended maintenance? Any advise is greatly appreciated.
My Ride: 2005 545i | Black Sapphire Metallic | Black Dakota Leather | Anthracite Maple | 6 Speed Manual | Sport Package | Logic 7 | Sirius Satellite Radio
Model Year: 2005
How many miles do you have on your car? Did you buy the car new?
The car is actually CPO. It has about 37000 miles on it.
My Ride: 545i
go to http://www.twinkidneygrill.com/maint.html Rodney will hook you up. There is a code you can input to save addtional $50, forgot what it was, can someone chime in on this. I purchased mine a couple of months ago, after what the dealer did for my X5 and my brother's 3 series well worth it.
On my X5 at 99XXX miles they
replaced oil
transmission fluid
transfer case fluid
spark plugs
all drive belts
oxygen sensor
brakes/rotors
same thing for my brothers E46.
replaced oil
transmission fluid
transfer case fluid
spark plugs
all drive belts
oxygen sensor
brakes/rotors
Model Year: 2005
Did you buy the car from a BMW dealer?
Model Year: 2005
Have you talked to your client advisor? You should be able to buy the extended maintenance plan, as well as the extended warranty, from your dealer if you bought the car new. I would give him a call to find out if it is possible and to check on the prices. There are other threads on here which discuss the difference is prices some dealers charge.
My Ride: 2011 550i AW - every option
Originally Posted by jaybas104' post='585732' date='May 21 2008, 10:22 PM
Hi guys:
100% worth it IMO. I have it to 100k miles.
Thanks for all the advises. I guess I should go with twinkidneygrill on this one?
