Dealer Extortion on Tires for 08 550i
First of all, I can't believe I need new tires already on my 2008 550i which has only about 20k miles, but whatever. So I have my car serviced recently at the dealer and he tells me I need new tires (I have the Continental Sport Contact 2s). The car is a lease.
Dealer tells me those are the only approved tires for the car and that I need to buy them from the dealer because my car has Active Steering Control and they have to do the alignment. I say "OK, how much?". Dealer says, including alignment, stems, etc, it's $2081 (+ tax I believe). I couldn't believe it. I ask if they can sharpen their pencil a bit since I've been such a good customer over the year (3rd 5 series for me) and he says that is as good as he can do.
So, I call around to my local tire shop (where I've bought lots of tires of the years) and find they can turnkey the entire deal including alignment and tax for $1,500 out the door for the exact same tires.
So my question is whether or not a quality local tire shop can do the alignment even if the car has active steering control. Obviously I'll buy the tires there. Only question is whether or not I'll still need to have the dealer do the alignment. It seems like extortion to me.
My Ride: 14 550i
buy the tires from your local shop and then bring the car into BMW for the alignment. i honestly couldn't tell you if you have to have BMW do the alignment because of active steering though.
if no one responds on the forum you could always give BMW North America a call and ask.![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
My Ride: 05 545/6
Originally Posted by porsche911targa' post='822271' date='Mar 20 2009, 02:28 PM
Wow, I suggest you try http://www.tirerack.com and try an independent BMW shop for the alignment. It would help to know your location so that others may chime in with shop suggestions.
don't buy that BS about contis being the only tires for the car, but if you're only replacing the rears you really should keep the same type as the fronts.
I'm in Monterey, CA. I'm replacing all 4 and the car does have Active Steering Control. Hopefully, I can get it done for less at local shop when I tell him not to do the alignment. I have to take car to dealer a week later for something else so I'll have them do the alignment for $275 (just called to get a price on that).
Thanks.
Thanks.
That price would be HIGH even for RFT's - Is your set up 225/50x17 or do you have 18 or 19 inch wheels. In any case you should check TireRack prices and use them for leverage for a lower price at a local / independent shop. Be certain to check the shop's experience working with BMW/high line wheels - some tire shops will cause you more grief than necessary.
Is the dealer telling to replace tires because they are at the wear bars - some dealers will replace tires when they still have 50% of life available.
As for alignment - 100% go with an experienced BMW dealer.
Just as an FYI, when I had a pothole take out a tire and wheel my dealer was within $25 of the TireRack Price for a Bridgestone RFT 245/40x18. And they charged me $30 to mount and balance - about the going independent rate for a RFT w/TPMS.
My Ride: .
Model Year: .
Thanks.
Thanks.
if you have active steering you have to go to the dealer i went to a indy for mine and i now have a active steering malfunction which means i have to go to the dealer and do it again im just going to wait and see if i change my wheels again before i go and do it over =]
