Alignment NOT covered under original 4/50 Warranty !!!!
My Ride: 2005 545i | Black Sapphire Metallic | Black Dakota Leather | Anthracite Maple | 6 Speed Manual | Sport Package | Logic 7 | Sirius Satellite Radio
Model Year: 2005
Originally Posted by EBMCS03' post='820436' date='Mar 18 2009, 03:23 PM
Many companies will cover alignment for a certain period of time, mostly 1K miles... but not the full 4 years 50K...
Ford covering 12K miles? WOW. but too bad... i still wont buy a ford just for that.
Originally Posted by z06bigbird' post='821724' date='Mar 19 2009, 08:52 PM
It would be covered then. Some warranties do not cover freon--unless the garage is replacing warranty parts--like compressor, evap, or condensor, etc.
(Consequential, related to a warrantied item.)
In that case would the following be considered as stated above.
...... While they were on it they also found some reddish fluid on the ground and after further investigation, found Front Active Sway Bar was leaking. Ordered parts for that too, will be done at the same time on Monday (under warranty).
Can a leaking Active Sway Bar cause the alignment problems over time. What is a 'sway bar' any way????
