What dealer in SoCal can give me bluetooth support
My Ride: 545, Auto, Sport, L7, Pdc, Sunshades, Silver Gray/Black, 19x8.5/9.5 Monet Wheels, Michelin PS A/S Tires, Full M-KIt, B&B Exhaust, 20% Llumar Tint
I have a 2004 / so far the dealers I have called (Sterling, Crevier) can't help / maybe I'm just reaching the wrong person?
I have a v600 and I'd like to make it work...ive read all the posts on the subject...but it sure would be nice to have a local dealer that can help
[snapback]56516[/snapback]
Originally Posted by Hormazd' date='Nov 15 2004, 04:50 PM
[quote name='ch7656' date='Nov 15 2004, 02:37 PM']I have a 2004 / so far the dealers I have called (Sterling, Crevier) can't help / maybe I'm just reaching the wrong person?
[snapback]56565[/snapback]
[/quote]7/04 so I'm fine (I think)...was just a little frustrated that the two aforementioned dealers had no idea how to help me They said all would be well in '05 but couldn't help with an 04...maybe I just got the wrong people at the dealer??
Originally Posted by Guest' date='Nov 15 2004, 05:02 PM
Just get the latest softwar eupdate and you'll have bluetooth (might cost you money tho)
[snapback]56568[/snapback]
I have what I think is the latest 13.2 or so...and my V600 can't find the car
[snapback]56569[/snapback]
Originally Posted by wnrussell' date='Nov 15 2004, 07:20 PM
[quote name='ch7656' date='Nov 15 2004, 07:11 PM']
[snapback]56601[/snapback]
[/quote]Thanks but even at 15 pages I don't think that post is going to steer me in the direction of a dealer in my local area that knows what the hell they are doing . And as I mentioned...at this point that's what I'm looking for...a dealer in my area that can help me...I'm not looking to help my dealer figure this stuff out. But again thanks for the link...I appreciate your attempt at helping
[snapback]56621[/snapback]
1. From the start menu press briefly down on the controller.
2. Scroll down to the "Communication settings" and select.
3. Select "Bluetooth" and press controller.
4. Select "Settings" and press controller.
5. Select "Bluetooth communication active" and press the controller to activate the connection.
6. Exit back to the start menu.
PAIRING THE HANDSET TO THE VEHICLE E60/E63/E64
Turn the key on.
Select "Phone" and press controller.
Once the message "Bluetooth connectable in this menu" is displayed the vehicle is in pairable mode.
Your handset should now be set to search for BT devices. See the Owner's Manual for your handset
In order to pair you must enter a random passkey both via the handset and via the CID. The passkey can be any number that you choose up to 16 digits long.
Via the CID select "Add device" and press controller.
Enter your passkey. Depending on the handset, you will have approximately 30 seconds to enter the passkey on the handset and the CID.
Enter the same passkey in the handset and in the display.
Select "Confirm passkey and press the controller.
After a few seconds your device will be listed.
Depending on the handset, the device will ask you to accept connection.
You must exit this menu in order for the handset to operate correctly.
Turn the key off. When the key is turned on the handset will connect and transfer the phonebook entries from the handset. This may take several minutes depending on the size of the phonebook.
My Ride: (Expecting Oct. 2004) 2005 530i Sport package, premium sound package,premium package, xenon's, HUD, sat radio, cold weather package, navagation
I know recently Crevier has been learning more about bluetooth maybe try them again
