VOICE/PHONE SYSTEM
i currently drive a 530i petrol m sport 2005 model
my old phone paired up to the car no prob worked a treat ive just changed phone to a nokia n73 now it pairs ok so car sees it and paskeys ok but it will not pick it up after so i cant use it at all!! any ideas??
also the voice control system has never worked i asked my dealer to check it when it was in for service and the SERVICE ADVISOR said all was ok but no matter what i do it will not work a i missing something??
any help/ideas appreciated
Ja, easy. You would need to be using a compatible mobile phone, then everything should work.
Since the old mobile worked, that?s definitely the problem.
Originally Posted by JSpira' post='514323' date='Jan 6 2008, 03:28 PM
Re voice command, do you mean just for the phone or the speech-to-text system that comes with the CCC.
Originally Posted by dcsprringlane' post='514333' date='Jan 6 2008, 11:10 AM
no i press button on steering wheel (little mans face with speech ) and nothing works at all!!
Originally Posted by JSpira' post='514336' date='Jan 6 2008, 04:13 PM
Ja, that would be in either case, but you didn?t answer my question: is this the voice command just for the phone or the speech-to-text CCC-based system.
umnitza
09-02-2015 11:28 AM
PelicanParts.com
07-23-2015 12:41 PM
