Verizon Blackberry Pearl 8130
The Verizon Blackberry Pearl 8130 is out this week. According to the Verizon site, it is not compatible with BMW kits. However, there are currently compatible Blackberrys that are listed as not compatible as well.
Has anybody hooked one of these up yet? Any thoughts? I have a 1-05 date of production 530.
Thanks
Thanks
sharpgator,
I'm considering the same phone through Verizon (I currently have a BB Pearl, through AT&T, and it works just fine). I don't know how often the compatability lists get updated, but Verizon's 8130 list must be pretty current since the phone was just released.
Why don't you go by a Verizon store and they'll let you do a test "pair up" with your car.
Let me know what you find out - I'm particularly interested in phonebook transfer and signal strength meter compatability. Good luck.
I have a question about BB Pearl (AT&T) and BMW BT: I paired my phone and it works just fine, but only the first 5 or so entries under each letter in my address book will load into the iDrive. Is this due to a memory limitation or something? If so, is there any way to store my most frequently called numbers, or change which ones it uploads? Often the most frequently called numbers are not among the first 5 alphabetically under each letter.
My Ride: G30 M550i
Model Year: 2018
Your problem sounds like a different one and it's the first time I remember hearing anything like that. Maybe there's someone else here who can shed some light on things...
Thanks
Thanks
Thanks
Thanks
Answering my own question. Due to the fact that so many BB's work with BMW, I took the leap and ordered the Verizon 8130. It paired perfectly and has had ABSOLUTELY NO ISSUES. I have about 550 contacts in my address book and it seems that all of them transferred. So far, it is the best phone I have had re: its performance with BMW bluetooth.
Hope this helps.
Hope this helps.
Originally Posted by DRANGED' post='493515' date='Nov 12 2007, 11:04 PM
I am using a Verizon Blackberry Pearl 8130 which I purchased over the weekend...works and pairs flawlessly.
