UK: Use of non-approved bluetooth phone?
My Ride: 530d Sport manual Mystic Blue, black Dakota leather, advanced air con, fold/split rear seats, Logic 7, business nav, 6cd, heated F seats
UK question - what integrated E60/61 functions would you expect to work with any (non-approved) bluetooth phone?
I would expect not to be able to use snap-in integrated cradle; therefore no phone charging available (any other down side of not using cradle)?
So phone would simply be somewhere in the car - glovebox/door pocket etc.
What would happen with an incoing call?
Could I make an outgoing call? How?
I'm a complete beginner with this - no idea how the integrated system works, so any help appreciated.
My Ride: BMW 535d SE Touring
Silver Grey / Beige Dakota
Media Pack (Pro Sat Nav, Bluetooth, Cd Changer, BMW Assist)
Visibility Pack (Bi Xenons, Hedlight wash, Adaptive headlights)
I'm using an 'unapproved' Nokia 6680 with my 535d. It pairs with the car, and I can make and receive calls, but I am unable to access the phone book or the recent calls list. Not sure if this would be the case for all bluetooth phones though
Peter
Peter
Peter
Peter
...and receive a call?
(I've never seen/used bluetooth connectivity - so I'm a total beginner - hence these questions!)
Originally Posted by petem77' post='254102' date='Mar 13 2006, 05:41 AM
How do you make a call?
Making calls is a little more difficult if you can't acccess the telephone 'phonebook. You can either use I-Drive to input the number (not recommended on the move!) or use the handset to select/dial the number. When you press 'call' the car responds in the same way as when an incoming call is received.
Hope that makes sense...
Peter
Sorry, should have added that pairing the phone and car is a one time event. You can also pair multiple phones to the car though (not sure how many; I only have 2 atm)
Peter
Peter
Thanks - that certainly does make sense. Exactly what I was looking for.
I've seen somewhere here that bluetooth use drains the battery more quickly than normal mobile use - do you find this?
Battery life on my Motorola V500 (an approved phone I think; the BMW bluetooth kit could access the phone book etc) had pretty poor battery life in the car. A day of driving would certainly see the battery almost flat. Wasn't a major problem as I just used a cigarette lighter charger (only a fiver...) to keep it charged.
However, it was one of the reasons I switched back to Nokia, as in my experiece they have much better battery life. This proved to be correct, as a day of driving seems to have little impact on it, though I have a charger in the glovebox just in case
Peter
Peter
Believe it or not the biggest thing I miss is not having a mute mic button on the bmw bluetooth system. My cheap handsfree had that!
Presumabley there's a microphone somewhere in the car - so you don't need to use the phone's mic?
If so where is it?
If so where is it?
The microphone is up in the headlining, by the map lights etc AFAIK...
Vman33
03-14-2022 04:43 AM
ucsbwsr
09-19-2015 10:58 AM
