Snap in cradle for Nokia 6300
Hi,
My Nokia 6300 works perfectly with BT, but I miss the possibility to charge it as I could with the cradlle for Nokia 6230i. Do'es anyone know if there ia a cradle for the Nokia 6300 ?
Originally Posted by plindegaard' post='456307' date='Aug 7 2007, 10:28 PM
Hi,
Yes, there is a snap-in adaptor for the Nokia 6300. Just installed one and it works fine, charging and antenna connection.
BMW Part No is: 84.21.0.439.150
BTW, it's not listed on any of the BMW compatability lists yet but if you ring your BMW dealer with that part no. they can get it.
Hi,
Cradle for the Nokia 6300, 3 versions available; Passive (pictured), Passive with tilt/swivel bracket, Active with built in charging cable (this ends in a cig lighter cable). Check out : newministuff. com/new/shop.php?action=productshow&id=507
Good luck
Good luck
Originally Posted by plindegaard' post='456307' date='Aug 7 2007, 04:28 PM
Hi,
ucsbwsr
09-19-2015 10:58 AM
slow.motoren.werke
DIY: Do It Yourself
08-25-2015 03:46 PM
