Reset loop TREO 650
I have am 11/04 build without NAV and have paired my TREO 650. It worked for a few days without access to the phone book. I followed some links from this forum and upgraded my version from PalmOne. I now have a reset loop that is happening only when in the car. I hard reset and reloaded the version upgrade into a new user (Temp) and re-paired. It worked fine but none of my data was in the phone as I used the Temp. Has anyone had this problem - and if so - were you able to fix it? Thanks!
Originally Posted by Green-Crayon' date='Jun 7 2005, 02:07 PM
I have am 11/04 build without NAV and have paired my TREO 650.? It worked for a few days without access to the phone book.? I followed some links from this forum and upgraded my version from PalmOne.? I now have a reset loop that is happening only when in the car.? I hard reset and reloaded the version upgrade into a new user (Temp) and re-paired.? It worked fine but none of my data was in the phone as I used the Temp.? Has anyone had this problem - and if so - were you able to fix it?? Thanks!
[snapback]137216[/snapback]
Hope that helps.
And I do sync several times a day - so, you are right - it's no big deal. The weird part is it only is in the reset loop when I am in the car with bluetooth on. It even resets when the phone is off in the car, with bluetooth on.
