Is it possible to replace MULF with MULF 2?
Confirming that it does in fact work... May need to be tuned with ncs because of the aux and bluetooth disabled in my mulf2 upgrade....
You will also have to compare and modify the mulf white connection to the blue mulf2 one, mulf2 has a blocked area and will need a dremel to sand it down. Once connected, you should get instant sound but with some features disabled.
Hi everybody,
In the same subject i m wondering if the ULF module is directly responsable of audio cut off and no mobile battery charging in the snap in also nô more BT
It s impossible to use my phone in the car
Impossible to check box for BT activation on display
I drive free wheel or freeze
Who s guilty ? ULF
I ve checked all connectors in the center armrest and behind CCC but everything was perfect
Thanks for info
Who s guilty ? ULF
Thanks for info
socale39
09-05-2023 08:30 AM
