Losing Bluetooth Link
I have a Moto Razr V3m that links fine with my 550i. The problem is that once a week, I lose the link between the phone and the car. It happens without warning, sometimes in the middle of a conversation. When it happens, I can't re-establish the link without turning off the car and letting it sit for awhile. When I turn it back on, the link magically appears again. The problem appears to be with the car since the phone still thinks it is linked and works with other Bluetooth devices (i.e. headset). One one occassion, the Bluetooth setting on the car seemed to be frozen. I couldn't un-check the Bluetooth link in the settings window.
Anyone else experience anything like this?
Delete the pairing and repair. See if the problem continues to occur.
Try another mobile, see if it happens with the other mobile.
That will narrow down the cause of the problem.
Originally Posted by JSpira' post='388555' date='Feb 7 2007, 08:07 PM
I?ve seen similar things happen with my S710a (which I no longer use although it?s a great mobile).
I'll just live with it until my first service since everything else works just fine!
Originally Posted by stanatl' post='388622' date='Feb 7 2007, 10:11 PM
However I'm pretty certain it is the car because the Razr works with a Bluetooth headset when the car doesn't recognize it.
Originally Posted by JSpira' post='388624' date='Feb 7 2007, 10:21 PM
I?m not sure I see how this proves it?s the car.
Each time that the car loses pairing with the phone, the phone recognizes and pairs normally with my Bluetooth headset. On one occassion, the car's Bluetooth link seemed "frozen" in that I couldn't un-check the Bluetooth setting and the car wouldn't let me delete the phone. Delteting and re-installing the phone does not work. On each occassion, the only way to re-establish the link was to turn the car off for awhile and re-start it. That allowed the link to occur without doing anything to the phone.
That's what has led me to the conclusion (possibly erroneous) that the problem is the car and not the phone. I may be wrong and will have BMW Service check the system when I bring the car in for maintenance. The problem, however, is sporadic and seems to go away when the car is turned off and re-started. I doubt that I will be lucky enough to have the problem occur while I'm driving to the dealership.
The pairing with the headset does not matter. The mobile is using different profiles to bond with the car. Best way to prove it is the car is to try another mobile.
Thanks for the feedback.
Originally Posted by stanatl' post='388766' date='Feb 8 2007, 09:13 AM
Point well taken. I will link my Treo 750 with the car and see if the same thing happens after a week or so. I won't have my entire address book but I will give it a try.
Originally Posted by JSpira' post='388821' date='Feb 8 2007, 11:54 AM
Uh, don?t do that. The 750 is not at all compatible.
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
What software version is the V3M running? Latest version is NEWC_01.05.0A. It's worth a looky-see, read somewhere about older software version acting up.
