How can I pair my Bluetooth phone with my car?
I think I can answer my own question after searching a bit more. This post pretty much explains it. My car was born 11/03 so I guess I am out of luck. Sniff, sniff. Oh well, I guess I will have to focus on driving the rocketship...
Best,
Mike
Best,
Mike
Originally Posted by mikew' date='Jan 21 2005, 09:20 PM
Hi folks,
Many thanks for the useful FAQ. Just like some other users I don't have a Bluetooth option in the communication settings screen. I have a 2004 545i. Does this mean I am out of luck and cannot use BT phone? I do have a printed card with a Passkey card.
Or is there an upgrade that BMW can provide? I must admit that I am pretty frustrated with the lack of guidance from BMW in this regard. I have recently had the car in for service for 10 days because I was told that the 545i is the "nemesis" of the service center because it is such a complicated car.
Anyway, if any of you can shed some light I'd appreciate it.
Cheers,
Mike
Cheers,
Mike
[snapback]81780[/snapback]
Guest
Posts: n/a
Does anyone know if you can do the same like w/ the treo650 in a retrofit e38 - 2001 740i?
Lomack,
My MY04 April build came with a BT passkey card, but I don't find "Communications Settings" when I press on the CID. What does this mean?
Originally Posted by dfndr' date='Jan 7 2005, 03:33 PM
[quote name='Lomag' date='Dec 5 2004, 11:33 PM']How can I pair my Bluetooth phone with my car?
ACTIVATING BLUETOOTH E60/E63/E64
This procedure must be carried out first in order to properly pair a handset to the vehicle.
1. From the start menu press briefly down on the controller.
2. Scroll down to the "Communication settings" and select.
3. Select "Bluetooth" and press controller.
4. Select "Settings" and press controller.
5. Select "Bluetooth communication active" and press the controller to activate the connection.
8. Exit back to the start menu.
PAIRING THE HANDSET TO THE VEHICLE E60/E63/E64
Turn the key on.
Select "Phone" and press controller.
Once the message "Bluetooth connectable in this menu" is displayed the vehicle is in pairable mode.
Your handset should now be set to search for BT devices. See the Owner's Manual for your handset
In order to pair you must enter a random passkey both via the handset and via the CID. The passkey can be any number that you choose up to 16 digits long.
Via the CID select "Add device" and press controller.
Enter your passkey. Depending on the handset, you will have approximately 30 seconds to enter the passkey on the handset and the CID.
Enter the same passkey in the handset and in the display.
Select "Confirm passkey and press the controller.
After a few seconds your device will be listed.
Depending on the handset, the device will ask you to accept connection.
You must exit this menu in order for the handset to operate correctly.
Turn the key off. When the key is turned on the handset will connect and transfer the phonebook entries from the handset. This may take several minutes depending on the size of the phonebook.
Up to 4 handsets can be paired to the vehicle.
Please consult the Owner's Manual of the handset for additional information.
Turn the key on.
[snapback]65294[/snapback]
[snapback]76765[/snapback]
[/quote]
My Ride: 2004 545i SMG / HEAD UP DISPLAY / DYNAMIC DRIVE / NAVI PRO / VOICE CONTROL
i have 03/04 545i SMG with NAV and Voice Control, but no Bluetooth function in the Communication menu, but i have the cellular phone Motorola in snap in adapter
what i need to do to get Bluetooth work?
My Ride: 2004 545i - Black
Hi Guys I need some help. I purchased a new TCU from Bimmernav and it came with a new BT Antenna. I keep getting an error code of 391 Main Telephone aerial, fault. I can't seem to clear this... My mechanic was using Autologic to activate the Bluetooth. I need to find a reputable Dealer in MD that know how to do this .... /Any help you can provide will be greatly appreciated.
Thanks
James
Thanks
James
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
Welcome Aboard!!
