GSM Snap-In Adapter reset ?
I just bought my car.
There is factory installed rear seat bluetooth handset with GSM Snap-In adapter in the center pedestal. I wanted to delete all the previous owners numbers and setting so I reseted the handset to factory settings. After this I am unable to pair the handset to Snap-In Adapter. I have tried and tried without any luck. When I pair the GSM Snap-In Adapter to i-Drive, it easily finds it and asks for pin number. Only accepted pin number is the previous owners pin ??? How can I reset the Snap-In Adapter ?
There is no difference whether I use my own SIM card or no SIM card at all. It still only accepts the old pin number.
I put a photo of the rear seat telephone which is causing this problem !!!
My Ride: 2004 BMW 525i, 6 Speed Manual, Premium/Sport Pkg, Xenon Adaptive Light Control
The bluetooth pin number is unimportant, it just a number both devices need to communicate in order to pair (connect). Use any number that works, you don't need to change the pin. My guess is you are worried about someone accessing the information on your SIM card. if that is the case, you can assign a pin on the card if that handset allows that functionality or talk with your phone company about securing the SIM with some sort of passcode. Hope that helps.
Sure I can use whatever PIN number I want, but the GSM snap in adapter ONLY accepts one PIN number when I am pairing the device with the i-drive. It is like a password which needs to be reseted. Only problem is how can I reset it ???
Vman33
03-14-2022 04:43 AM
umnitza
11-03-2015 02:58 PM
