fao DocDiesel
A quick question or two...
my unit came with car charger only, no mains, even though the box said it included both (supplier said it will come later - a week or two) -- did any of you get mains & car or just car charger only?
and, more importantly my good doctor...
how do we pop that panel to place the clip like you've done? and in my case, with a sunroof switch, is it possible to pop the edge out only (since the button for the roof obviously is added over the panel?)
- and have you a photo of the final product, by any chance?
cheers
cheers
cheers
cheers
same here..
I've also found out that if you turn the volume up too far, the other party gets an echo...
This dsp thing doesn't seem to work too well.
BTW, the panel just pops out.
yep - i've found the echo problem as well - which is why they probably ship it with the microphone --- similar tho' different problem as i had with the parrot driveblue
i think the visorcom is getting sent back, tomorrow.
Originally Posted by E60525d' date='Aug 21 2004, 12:09 AM
what if you want to make a private conversationa and people are in the car? is there any way or do i need a bluetooth ear piece?
Our Visorcom arrived with car chareger only, but also with a polite note apologising for the fact that the factory had omitted the mains charger and that they would send the charger as soon as they received them. In fact it arrived in the post 48 hours later. This was from Tarnsparent communications. Very efficient
panel just pops out from the front edge
my mains charger arrived a few days later (again from Transparent)
yes, if you switch it up really high it will echo but Mine doesn't echo at all at the correct volume setting.
as far as privacy goes, you get a plug in earpiece with it but frankly I've never bothered to use it.
all in all, for the low cost, I think its just fine!
DD
sorry for the delay...been away at a track day all weekend......porsche/ferrari/bentley/masarati ............HEAVEN! ......no, didn't track the E60
DD
