Dension Gateway 500 + BLT1500
My Ride: 530 2005 E60
Hi all.
now i got the GW500 working almost like a charm.
Harddrive working perfect.
the ipod like a charm.
streaming Spotify from iphone by bluetooth sounds great
asnwering the phone on the phone and use the mic and speakrts by bluettoth goes great
BUT
i cant see the phone in the "blue " menu in the car
the car tells me that there is no mobile device installed.
i think i need togoback to the dealer and have them program the BLT in the car.
They told med that they need to know what kind oc number they shall install.
As there are 3 differend BLT numbers that can be programmed.
Have you guys any idea on what is the right number that they can program the car with. wich number does teh Denstion BLT emulate ?.
Really thankful for help.
BUT
Originally Posted by X3MKing' post='1027107' date='Oct 7 2009, 05:18 PM
Hi all.
BUT
BUT
Does the number 91 77 754 make any sense to you ?
Hi X3MKing,
Did you get sorted with this install and did you find out what "oc number" was needed?
I have installed the same as you, Gateway 500 + BTA1500. My setup works as you describe so I am booked into the dealers for Bluetooth retrofit programming. They said they had not done this before, so the more info. I can give them the better. Would appreciate any help.
Cheers.
Cheers.
[Did you ever get to the bottom of this problem, im having the same problem with my 1 series.
I might be getting the system removed if this can not be solved.
I found a Auto logic guy how programed the car for the Dension unit
Problems the same as others , shown below
[/quote]
[/quote]
bestofthebest
03-28-2016 02:47 PM
wooboodoo
10-25-2015 02:58 PM
Bank$hot530
09-16-2015 01:28 PM
