Dailing numbers via bluetooth after connected
OK Lets stop arguing on how to do what he wants. You can use the keypad and the I-drive. The i-drive is a painfully slow and requires as much driver distraction as using the keypad on the phone. I use them both depnding on the circumstances.
To use the I-drive, when in a call push down on the pod. You are given a choice of "End Call" or "KeyPad" Select Keypad.
If all I have to do is dial an extension and the phone is in my trouser pocket then I will use the I-drive, however if you have to dial a string of numbers as a password to get to voicemail, then I use the phone keypad.
Lets face it, checking your voicemail while driving is a distraction no matter how you dial. Its a risk I take.
Originally Posted by Hormazd' date='Jan 24 2005, 09:02 PM
OK Lets stop arguing on how to do what he wants.? You can use the keypad and the I-drive.? The i-drive is a painfully slow and requires as much driver distraction as using the keypad on the phone.? I use them both depnding on the circumstances.
To use the I-drive,? when in a call push down on the pod.? You are given a choice of "End Call" or "KeyPad"? Select Keypad.
If all I have to do is dial an extension and the phone is in my trouser pocket then I will use the I-drive,? however if you have to dial a string of numbers as a password to get to voicemail,? then I use the phone keypad.
Lets face it, checking your voicemail while driving is a distraction no matter how you dial.? Its a risk I take.
[snapback]82671[/snapback]
Originally Posted by gdavis' date='Jan 24 2005, 07:06 PM
[quote name='Hormazd' date='Jan 24 2005, 09:02 PM']OK Lets stop arguing on how to do what he wants.? You can use the keypad and the I-drive.?? The i-drive is a painfully slow and requires as much driver distraction as using the keypad on the phone.?? I use them both depnding on the circumstances.
To use the I-drive,? when in a call push down on the pod.? You are given a choice of "End Call" or "KeyPad"?? Select Keypad.
Lets face it, checking your voicemail while driving is a distraction no matter how you dial.?? Its a risk I take.
[snapback]82673[/snapback]
[/quote]You are welcome.
My Ride: 535d, Nav Bus., PDC, saphire black, dakota beige leather, heated front seats, xenon, shades, bright brown poplar, standard seats with electric adj. and mem., automatic climate control.
with me, i just push the lower left button on the steering wheel for voice control, and i say "dial number" then i say the number. just my .02$
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
Bank$hot530
07-12-2015 04:36 PM
