Charging problem with cradle
My Ride: 530i 6 speed
OK, I have fianlly installed the cradle etc.
Was easy with all the posts here (thanks!!!!!!!!!).
It seems that the external antenna is working, but the V551 phone is not charging
I have searched the posts, but haven't found anything. Any ideas?
.I have searched the posts, but haven't found anything. Any ideas?
Here are the part numbers I have for the adapter and eject box:
84 21 0 307 726
84 21 6 946 075
I remeber a post here a while ago, but I can't find it.
I was so excited I got all this done in ~ 1 hour and now it doesn't work...
84 21 0 307 726
84 21 6 946 075
My Ride: G30 M550i
Model Year: 2018
The following thread may help you out. Unfortunately I'm not sure if this was ever resolved...
http://forums.e60.net/index.php?showtopic=8202
84 21 0 307 726
84 21 6 946 075
84 21 0 307 726
84 21 6 946 075
[snapback]132886[/snapback]
Edit: Here is the thread
My Ride: G30 M550i
Model Year: 2018
I think the wire in the trunk is for the antenna. The link Hormazd posted is a good one though because it illustrates a solution to a charging problem as well...
Originally Posted by Rudy' date='May 24 2005, 10:15 PM
I think the wire in the trunk is for the antenna.? The link Hormazd posted is a good one though because it illustrates a solution to a charging problem as well...
[snapback]132899[/snapback]
It seems that the external antenna is working, but the V551 phone is not charging?
[snapback]132881[/snapback]
Originally Posted by Magneto' date='May 25 2005, 07:22 AM
[quote name='drjochen' date='May 24 2005, 07:00 PM']OK, I have fianlly installed the cradle etc.
[snapback]133006[/snapback]
[/quote]I have the same issue with my v551 (rock in desktop charger stand to get it to work)
Remove and insert v551 in car 2/3 times a day. Has never not connected or charged properly. Easier to connect phone in cradle than to the car charging adapter.
Have u checked the original parts (snap in adapter and interface [eject box])? Reports of these coming bad upon receipt.
Originally Posted by cobradav' date='May 25 2005, 03:54 PM
Remove and insert v551 in car 2/3 times a day.? Has never not connected or charged properly.? Easier to connect phone in cradle than to the car charging adapter.
Have u checked the original parts (snap in adapter and interface [eject box])?? Reports of these coming bad upon receipt.
[snapback]133142[/snapback]
How do I check the orginal parts? Exchange them?
I assume the adapter 84 21 0 307 726 is the correct one for my V551. Can anybody confirm this? The dealer had no clue whatsoever...
