BT question
Is there a way to turn BT off if you do not want use it, if lets say you have other people in the car and you want switch to the phone itself for privacy reasons?
Originally Posted by alex123' date='Jan 14 2005, 09:17 AM
Is there a way to turn BT off if you do not want use it, if lets say you have other people in the car? and you want switch to the phone itself for privacy reasons?
[snapback]79092[/snapback]
You can either drop connection from your phone... as per last post this varies in difficulty from phone to phone, on the Nokia 6310i is is easy to do... just press options while call is in progress and then OK. Alternatively you can turn BT off in the i drive menu. Press controller down and select Comms interface and un check the BT box.
[snapback]79100[/snapback]
Originally Posted by Hormazd' date='Jan 14 2005, 03:01 PM
[quote name='speuk' date='Jan 14 2005, 09:40 AM']Alternatively you can turn BT off in the i drive menu. Press controller down and select Comms interface and un check the BT box.
[snapback]79141[/snapback]
[/quote]It's pretty easy on my Motorola V600, all I do is pick up the phone and switch the headset option to off...
On my SE T637 I just pres the joystick and I get a "transfer sound", I select that and it gives me a choice of phone or other BT devices I have created, like my JABRA BT Headphone
aqualibrium
07-21-2015 03:11 AM
