I have an early 2004 530i. I've 2 problems and am wondering if anyone can give some advice.
My car is BT equipped and has the CP9000 phone but I can't get the car to connect to the phone: 1. I activate BT through i-drive 2. I turn on the CP9000 and scan looking for BT devices. The phone doesn't pick up the car. Anyone have a clue what could be causing this? I also want to get rid of the double chip - which is a real nuisance to use as I have to activate my mobile everytime I step out of the car. If I buy a motorola which works with BMW, could I do away with the 2nd chip or does the car need that anyway to activate it's phone? Thanks. |
You need to be in the bluetooth settings screen on the idrive to allow the handsfree to be "visible"
CPT9000 and Bluetooth are mutually exclusive. CPT9000 is not Bluetooth. Go to our information page and look for the PDF manual on Telephone Users Manual. After reading that and you still have questions then get back with us. I assume this car is NEW to you and that it has not suddenly changed how it works. It is possible to SWITCH to Bluetooth and not use the CPT9000 and that is/was done by dealer. Not remembering that far back, but you may also want or need to go to the BTUM to get Bluetooth. You can search for BTUM in this forum (BLUETOOTH and CELL PHONE) to find out more on this new upgrade possibility.
You're right-I've had this car for 4 months but could never get the pairing to work, replying only in the i-drive. I'm now able to pair CPT9000 and car. If I understand you correctly, my car will only work with the CPT9000 and a double sim card and until I get an upgrade (not sure if that's the CTU?) I would not be able to connect through a single sim card inside say a RAZR? If anyone has a CPT9000 - how can I tranfer my phone book from my normal phone to the CPT? If I moved phone book to 2nd sim card, will CPT9000 see contents of the sim? Thanks again! |
