is bluetooth possible in my e60?
Old Oct 10, 2005 | 09:44 PM
dv8ed's Avatar
I have an '04 BMW 525i 09/03 production last seven of VIN: B173342 is it possible to install bluetooth in my car?
I could of sworn I read some posts a while back that someone successfully installed bluetooth by changing the right TCU on a 09/03 production E60.
I'm sure I will have to change the TCU and reprogram the i-drive software.
Can someone give me part numbers?
Thanks!
Old Oct 13, 2005 | 07:30 PM
wdb44's Avatar
Unhappy
[snapback]182537[/snapback]
I have a similar model, an '04 530i that I picked up in at the factory. The engineer told me that the car was equipped with all the BT hardware but the software had to be activated. I have asked my dealer about it repeatedly, but they know nothing! I have a card with a PK# and all the BT info that came with the car, but when searching for a signal from inside the car there is none. I think it needs to be activated somehow, but I do not know if I have the software to do it.
I've put a link on this post, but if you get any answers I would appreciate it if you could let me know!
Thanks, and good luck.
David Brown
Old Oct 28, 2005 | 07:04 PM
nixter's Avatar
My Ride: 2004 545i,silver grey metalic, sport/premium package,nav,pdc,chrome style 121,logic7 sound
David,
If your car was built in 3/04 or later it has the proper TCU. All you have to do is have the dealer install the software, which is easier said than done. Some dealers will tell you your 04 is not capable without a new TCU even if it was built in 3/04 or later. Don't listen to them. Refer them to SIB (service info bulletin) # SIB841304. It may cost you a few dollars (cost me $300) depending on your dealer. If you have the software installed, you need to go to your communications settings on your main menu and make sure the "bluetooth" option is checked. If you don't see "bluetooth" anywhere on the communications menu, the software is not installed. Go to the "inofrmation" page on this site and read the phone instruction manual. It is very helpful. Had it not been for this site, I would have let my dealer tell me there is no way for me to have bluetooth without buying a new TCU. Good luck.
-Nick
Old Oct 28, 2005 | 07:54 PM
ademitt's Avatar
Originally Posted by nixter' date='Oct 28 2005, 09:04 PM
David,
If your car was built in 3/04 or later it has the proper TCU.? All you have to do is have the dealer install the software, which is easier said than done.? Some dealers will tell you your 04 is not capable without a new TCU even if it was built in 3/04 or later.? Don't listen to them. Refer them to? SIB (service info bulletin) # SIB841304.? It may cost you a few dollars (cost me $300) depending on your dealer.? If you have the software installed, you need to go to your communications settings on your main menu and make sure the "bluetooth" option is checked.? If you don't see "bluetooth" anywhere on the communications menu, the software is not installed.? Go to the "inofrmation" page on this site and read the phone instruction manual.? It is very helpful.? Had it not been for this site, I would have let my dealer tell me there is no way for me to have bluetooth without buying a new TCU.? Good luck.
-Nick
[snapback]190338[/snapback]
Nick not all 3/04 cars have the updated TCU (speaking from experience). The actual changeover occured between the 8th and 12th of March of 04.
The part number for the updatd TCU I believe is 6955688.
Old Oct 28, 2005 | 07:57 PM
nixter's Avatar
Good to know. I must have been one of the lucky ones
Old Nov 15, 2005 | 10:21 AM
rah's Avatar
rah
My Ride: 525dA LCI 08, space grey, M-tech, Advantage, Comfort, Nav Pro 8.8, voice, black dakota, seat heating front and back, active steering, comfort access, comfort seats, glasroof, auxiliary heating, head-up, night vision, bluetooth, DVD multimedia package in backseat, satin chrom, auto headlight control, PDC, adaptive headlights, CDC, HIFI, remaped 240hp 500nm
How do I get hold of a copy of the SIB841304 document.
I was told by my dealer that I had to install a BT unit and all the wiring. 3000 Euro!
Old Nov 16, 2005 | 11:33 AM
my530i's Avatar
Follow this link:
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B841304g.htm
socale39
Sep 5, 2023 08:30 AM
nmc
10
May 15, 2016 07:07 PM
zz545
Nov 13, 2003 12:31 PM
paasan
Nov 5, 2003 03:03 PM
ZeZe
Oct 15, 2003 12:58 PM
