Bluetooth Conflict w/ new iDrive software
My Ride: 07 550 Blk/Blk Sport, HUD, Night Vis, Actv Str, Logic 7 w/ HD & Sat, iPOD, Cold Wthr, Comfrt access, shades, 20x vented seats, rear heat splt fold, K40 Radar
03 525 Kalahari Beige / Tan, Sport, little Dinan stuff
In the 16 weeks I have had my CPO 2007 550, I have been plagued with and psoted many iDrive / computer issues. Dealer finally replaced CCC which , as I understand it, is the hardware. It was replace with a newer (maybe NOT newest i.e. 2008) version of hardware plus loaded on the latest software.
Up until now, I had no problem using my Bluetooth phone and Bluetooth enabled Radar detector (plus I know the previous owner and no problem there). I cannot tell you what part of this detector is Bluetooth, I was just told it is, most probably the remote. Now, if the dectecor is on, pairing the phone is not an option, even forced and if I pair the phone first, the radar detector will not operate.
Anyone else have conflict issues? I wonder why now with the new CCC ?
Thanks
Thanks
Thanks
Thanks
Originally Posted by luigi524td' post='685745' date='Oct 5 2008, 01:01 PM
Check to be certain that your cell phone isn't pairing - or trying to pair - with your radar detector. BT will not permit two devices to pair simultaneously. To troubleshoot turn the radar detector off and then go through the pairing process with your phone and car. Look for paired devices available on your phone and remove any device EXCEPT your car.
Originally Posted by deviandia' post='685830' date='Oct 5 2008, 05:06 PM
Yup, I know exactly what you're speaking of and it is not. The message I get is something on the order of "this operation is unable to function" or some version of that. Now that I have the new hardware and software, it just will not allow my phone and radar in the same car but before, it was a non-issue. Wierd
Yup ... that is weird. BT can be tricky but it's frustrating when s/w or firmware updates REDUCE functionality. Sort of like expecting government intervention to fix things in the financial sector!
Long known issue:
For instance: you cannot have TWO paired phones connected at same time. See SIB from 2006.
SI B 84 18 06
Communication Systems June 2006
Technical Service
SUBJECT
"Low Bluetooth Signal" is Displayed in the Handset or the Bluetooth? Connection is Lost
MODEL
E46 (3 Series) from 9/04 production (325i/iA from 10/04 production) with Premium Package (ZPP) or BMW Assist? (SA 639)
E53 (X5) from 10/04 production with Premium Package (ZPP) or BMW Assist? (SA 639)
E60, E61 (5 Series) from 9/04 production
E63, E64 (6 Series) from 9/04 production
E65, E66 (7 Series) from 3/05 production
E83 (X3) from 9/04 production with Premium Package (ZPP) or BMW Assist? (SA 639)
E85 (Z4) from 10/04 production with Premium Package (ZPP) or BMW Assist? (SA 639)
E90, E91 (3 Series) with Premium Package (ZPP) or BMW Assist? (SA639)
SITUATION
The customer may complain about the following issues when their compatible Bluetooth enabled handset is paired to the vehicle.
* Bluetooth connection is lost.
* "Low Bluetooth Signal" is displayed on the handset.
* "Low Bluetooth Signal, Use Handset?" is displayed on the handset.
CAUSE
Another Bluetooth enabled device is installed in the vehicle or is within close proximity to the vehicle. E.g. Calibre K40 (Bluetooth enabled) radar detector.
PROCEDURE
Inform the customer that the secondary Bluetooth device needs to be removed from the vehicle for the Telematics Control Unit (TCU) and their handset to communicate correctly.
WARRANTY
Information only
SI B 84 18 06
Technical Service
SUBJECT
MODEL
SITUATION
CAUSE
PROCEDURE
WARRANTY
Information only
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
I routinely have multiple bluetooth radios pairing in my car at once.
My Mot Q pairs thusly...
Mot-S705 (A2DP/AVRCP)
Q--------------Tether/serial-modem----------TomTomGPS
E60 (handsfree+PBA)
That's no fewer than 4 radios in the car, and the phone is pairing with 3 different devices at once. All -different- profiles mind you. What -isn't- permitted is to have something pair to more than one device over the same service.
I would suggest contacting the radar detector company to see if there is a way to have the detector only pair for the service profile that it alone can provide. If it's trying to do one that the car is doing (like handsfree), then there will be a conflict.
A perfect example to help illustrate is that my Motorola S705 device can be setup to pair only as a Stereo Bluetooth device, -or- it can be set to pair as handsfree/headset along with the stereo audio. If I were to configure it to pair as both, there would be a conflict between the E60's handsfree/headset and the S705's handsfree/headset. The first one paired to the phone would prevent the other one from pairing. Depending on the way the BT stack on the devices worked, a full capabilities negotiation check might be required for -any- services to pair. In other words, let's say 3 services are set to pair between BT devices. If for example one service were to fail, it might prevent the other 2 profiles from negotiating and communicating.
E60 (handsfree+PBA)
My Ride: black 2004 e60----comfort package, light package, tinted windows, custom coded features
There should be a way to configure the radar detector so that BT is not active. You can do this in your phone and in the car as well. My guess is that the radar detector is trying to use the same "Handsfree" profile that your phone is using with the car. You might want to try and see if you can pair the radar detector with the phone first, then procede to pair the car with the phone. Sort of use the phone as the central device.
Germaniks
08-09-2015 10:46 AM
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
