Bluetooth annoyances
Old 12-02-2004, 07:48 PM
  #21
John W's Avatar
Originally Posted by Hormazd' date='Dec 2 2004, 05:37 PM
[quote name='John W' date='Dec 2 2004, 04:33 PM']Also annoying, if I select a name in iDrive from the book, and push teh button, the call/dial command is grayed out.? I have to select the name in iDrive, and use the telephone button on the wheel to dial.
Seems odd.
[snapback]63665[/snapback]
Actually I think they are greyed out if there is no signal. I often see even the call icon greyed out if that is the case.
[snapback]63669[/snapback]
[/quote]
figured it out - it's grayed out if there're any waits or pauses in the number. straight numbers are fine, but 5551212w123 gives grayed out dial option in iDrive.
Old 12-06-2004, 01:54 PM
  #22
3rdFIVE's Avatar
My Ride: 2005 545 / SP / SMG / CWP / L7 / Sapphire / Blk / Anthr 2003 M3 / SMG / CWP / H-K / Titanium / Blk / (retired) 1999 540 / SP / Audio / CWP / Step / Jet / Blk / (retired) 1997 540 / Audio / CWP / Step / Jet / Blk / (retired) 1994 Acura Legend Coupe / 6spd / Blk / Tan / (retired)
I have the 5 rings and out problem on a SE T637 as well.
Old 12-06-2004, 02:14 PM
  #23
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Welcome aboard, 3rdFIVE !
Old 12-06-2004, 02:44 PM
  #24
alohalc's Avatar
welcome aboard, 3rdfive !
Old 12-08-2004, 10:14 PM
  #25
jared1234's Avatar
[snapback]65721[/snapback]
If I let the phone ring the car answers without giving me a choice to screen the call. (very annoying) Does anyone have a solution for this? I also get cut off after the 4th ring and can't leave a message on any voicemail. Is anyone working on these proplems? I work on the phone while I'm driving. I find myself just turning off the bluetooth most of the time and holding the phone. Kind of defeats the reason I got these features. I have a v600 on T Moble. Anyone have any idea who I should target for solutions? Thanks.
Old 12-08-2004, 10:29 PM
  #26
Hormazd's Avatar
Originally Posted by jared1234' date='Dec 9 2004, 12:14 AM
[quote name='alohalc' date='Dec 6 2004, 04:44 PM']welcome aboard, 3rdfive !
[snapback]66880[/snapback]
[/quote]
You should need to press the accept or reject button. Check your settings on the phone. I think under car settings or handsfree you have auto answer set to on. Turn it off and try again. The 4th ring problem is why I started this thread. No resolution AFAIK.
Old 12-08-2004, 10:48 PM
  #27
jared1234's Avatar
Originally Posted by Hormazd' date='Dec 9 2004, 12:29 AM
[quote name='jared1234' date='Dec 9 2004, 12:14 AM'][quote name='alohalc' date='Dec 6 2004, 04:44 PM']welcome aboard, 3rdfive !
[/quote]
[snapback]66883[/snapback]
Thanks for the tip on auto answer. It worked! Don't know what AFAIK means, but is there anything we can do to get someone working on the 4th ring problem?
[/quote]
Old 12-09-2004, 06:01 AM
  #28
Guest
Guest
Posts: n/a
I get to answering machines but that's because the places I call have the answering machine pick up after four rings. Someone should fix that, it should be toggleable or something.
No call waiting is annoying from the wheel is annoying, but then this was a limitation with the CPT8000 system as well. You can use your handset directly to switch over in the meantime. This is especially useful during hairpin turns.
The biggest annoyance for me is not being able to distinguish multiple numbers under the same name using voice. There's a workaround that doesn't involve changing the text string in your address book, but it would be better if the display actually showed you which were home, office, whatever. I don't actually know for most of them and have to guess which number I want. Of course, I suppose if that were the case then they'd just do the voice command correctly.
BTW, I think there's a feature I don't like: I have the same phone number under both my name and the name "home". It only shows up under home. I think it gets rid of duplicate numbers or something.
Having said all that, I am amazingly happy with this system especially the quality of voice and the who magical connection thing. It's great.
Peace.
Old 12-09-2004, 06:02 AM
  #29
m630's Avatar
[snapback]65698[/snapback]
welcome aboard
  #30
isbell's Avatar
Whoops. That was I.
Peace.
Quick Reply: Bluetooth annoyances
