Bluetooth for 04 545 with Nav
Originally Posted by odonns' post='233876' date='Feb 2 2006, 09:43 PM
Hello, I have a 04 545 with Nav and was told that it is not BT capable. Is this correct? is there a software upgrade? has anyone done this on their 04
Rich
Rich
[/quote]
Rich, My car was built in 05/2004. I called the dealer today and they knew nothing of a SW upgrade. Is there something specific i should be asking for?
Thanks Again
Sean
Thanks Again
Sean
Thanks Again
Sean
Is there another dealer in your area that you could go to ? where are you located ?
Rich
I did mine but had to bring in the printed update record (sorry forgot what these were called..CIP,SID,SOMETHING?). Once they took that record (which has a number assigned to it), they did the software update. Works prefectly now.....but your car has to be made after 4/4 date.
best of luck
best of luck
My Ride: Now Driving a Freakin' Prius!
Was...
2004 545i | SMG | White/Black | Sport | NAV | Logic 7 | PDC | Fold-down Seats | Adaptive Headlights | Cold Weather Pkg | Clear-again Bra | Mud Flaps | Bluetooth | Coat Hangar | Aux Input | All Weather Mats | 18"X8.5" BBS RK w/ Michelin Pilot Alpin's (winter) | New steering rack @ 1.2K & 17K miles| Software V.19.1 | B&B Exhaust (vrrrroooooommm!) <---Click.
I took delivery on my car in early April of 2004. I use my Bluetooth every day! I think the build date cutoff is eary March (Rudy?) unless you get a new CPU. I did need to have it activated later (didn't work when I first got the car but with one of my many Software updates it now works).
Welcome to E60 Forums odonns,
Please post your location in your personal data and the specifics of your car. It makes replying to geogrpahically specific options easier.
If you are in North America and your car was produced after March 8/04, you should be BT ready with the appropriate hardware (TCU) alredy installed. You will require a software update and to have BT activated by your dealer. ALthough you car came with the necessary hardware, the software for BT is likely not activated. You will have to pay for the activation of the BT but not for the software update if the update is eprformed to correct problems with the vehicle..
jcolley
08-01-2016 06:48 AM
Bank$hot530
09-16-2015 01:28 PM
E61mendo
09-15-2015 03:55 AM
