Better Bluetooth Streaming
#171
Administrator
UPDATE: Happy to report that I was finally able to complete this project with the help of an electrical engineer friend who identified the connections and soldered the wires for me.
I am ecstatic with the results!
The audio volume and quality is excellent and I'm able to have both the Waze for traffic reports app and Pandora for music app running at the same time over my Prologic 11 speaker system. I have a magnetic mount for my phone on the dash vent and can easily see artist/song information and flip back and forth between the music app and Waze. Incoming and outgoing phone calls pause the streaming until the completion of the call. I am leaving my Sirius subscription behind forever.
#172
My Ride: 13 X5 35i M-Sport (Sold) 535i M-Sport - (Sold) 07 530i Sport Gray - (Traded) 04 530i Sport Gray
I actually installed a Aux port up front to use with Aux cable to connect my phone. My 2004 530i Sport does not have Aux connection on the panel back there. But does it have the wiring behind the panel? Just curious about what I'd be actually soldering back there if the panel doesn't have an Aux jack??
#174
#175
Administrator
It might be easier just to install the board behind the glove box. You should be able to tap into the cigarette lighter wires from the port underneath.
#176
I was using a USB stick style bluetooth that plugged into my rear console aux line. This was "sufficient" until my 6 year old snapped it in half while sitting in the middle seat.![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Not to be dissuaded, I looked for a more "integrated" solution. Enter the Pure Electronics Bluetooth receiver. Full 2.1 + EDR bluetooth with the APTx codec means high quality audio. 12volt input makes for easy hookup with no messing around with power adaptors or any other nonsense.
![](http://i59.tinypic.com/2k4ya1.jpg)
First step was wiring 12v to one of the cigarette lighters. This is easy as you can solder directly from the bluetooth receiver PCB to a couple of points on the cigaretter lighter housing with only a few inches of wire in between.
Then I had to crack open the AUX module and using a meter to determine what was left channel, right channel and ground, soldered in some scrap RCA cables and drilled a hole out the back of the module so the RCAs could jack directly into my shiny new Bluetooth receiver. Finished up by mounting the PCB to the top of the AUX module with a little double sided tape and...
![](http://i59.tinypic.com/6omx6s.jpg)
I don't understand the other side of this board: The RCA red/white is plugged in on this viewable side...what are the red/white cables going to underneath??
Then snap the cover back in. Yes that's the same pic as the before picture. Point being that externally, there's nothing to see here. Super clean, super stock.
![](http://i62.tinypic.com/23r22q0.jpg)
I don't have this....I added one up front using ROSKINC Aux DIY -- so I'll be doing mine up front...??? Is the back side or inside of the Aux what the red/white RCA cable leads are being connected or soldered to???
#178
Administrator
#179
My Ride: E61 520d 2007
Has anyone experimented on sound quality differences between headphone jack and RCA outputs of the Sure Electronics board, which is the better way of connecting to a E60 aux-in?
Anxiously waiting for my board to arrive...
#180
![Smile](https://5series.net/forums/images/icons/icon7.gif)
Yes, the RCA wires are soldered to two points on the AUX board. or... (see below)
I disconnected my AUX jack wire harness and used a 3.5 mm male headphone plug from an old set of headphones and just tapped into the harness wires. Then that plugs into the Sure board. (see pic below)
And I note in your pic you don't have the red/white RCA plugs going into left/right channels of the Sure board...perhaps b/c you have my setup...no Aux 'board' that the plugs wld be soldered to (Aux board)?? So w/no Aux board it's just the one connection frm Aux cable to Sure middle jack?? I did note one of your pics has the white headphone jack in middle and a black plug connected to the side jack(of Sure board)...not sure what that's about/for.
Then, the cig lighter connection (power): I don't fully grasp this yet. I believe a wire is tapped or spliced to go to Sure board (soldered somewhere on board). I wld like to have the option of listening to music with car off though...which might require another power source frm my limited understanding.
Thanks for walking me through this. I didn't want to order board before fully understanding - nothing worse than going in and missing something then having to put things back together unfinished! I think I'm ready to order the board now!
