Better Bluetooth Streaming
#121
My Ride: 2006 530XI
hey can someone help a brotha out? Im not good with stuff like this. Do I just wire up a ground cable to where it says "GND" and a power cable to where it says "VCC"? And also, is the other port in my photo a power port? can't I just power it via this? thank you!
#122
My Ride: 530Xi
Hot wire, run from circuit breaker or you can tab onto the Positive cigarette lighter near by, to VCC. And ground wire from any bared metal of the car frame to GND.
The other power port has the same function if you are using the power adapter. But hard wire like above is better
#123
My Ride: 2006 530XI
The other power port has the function if you are using the power adapter. But hard wire like above is better
#125
My Ride: 2006 530XI
I have to say, THANK YOU!!!!
I just finished installing the sure BT receiver in my 2006 530XI. It sounds AMAZING. Perfect volume, no noise, just great! I tried every single fuse in the glovebox hoping to find a switched source... nope. Had to remove the trim in the passenger footwell side and tap into the 12v outlet there. Again, sounds amazing!
This pic was right before I decided to just wire it up to the 12v outlet under the glovebox... This whole thing was a lot easier than I thought. Got some double sided tape and mounted it where the cd changer would go. with the fuse cover in place you would never know the sure receiver was there
#127
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
Great Job!!
#128
My Ride: 2008 6MT M-sport 550i
Tried this a few weeks ago but definitely did it wrong. I'm not very inclined with raw audio components and such. Where should these wires be soldered to? What about the shielding in the RCA cables, do I do anything with that or just cut it away?
I reverted to using an aux cable but would prefer to have the rca cable method.
Thanks.
Thanks.
#129
My Ride: 2008 528i, Dynamic Drive, Active Steering, Nav, Adaptive Xenon, Comfort Seats
The RCA jacks on the SURE module seem to output a line level out signal which is very low in power and gets degraded when going through the capacitors on the aux input board. If you check the board for aux in, you will see two capacitors below the 4 pins that bridge the left and right channels to ground. Seems that it could be a filter or some kind of protection device for the amp? Because of this I think you need to use the headphone jack output from the board to get the best audio quality. The headphone jack on the board outputs a much higher power signal and might work better.
When I tried using just the RCA cables, the sound was horrible, much worse than my old bluetooth usb aux module and way worse than just normal aux. The bass was overly boomy and weak while the highs and mids were nonexistent. It pissed me off so much that I ripped the module out of my car right after installing it and went back to bench testing it where I found out about the difference in power. Going to try again tomorrow with the headphone jack and will see how that goes.
Have any of you tried wiring the module directly to the aux wire, completely bypassing the aux box and board? Wiring it that way will bypass the capacitors and I think should achieve the "aux cable mod" that people were doing to their pre-LCI cars.
Update: Figured out what was wrong, my grounds did not have a good connection. Also removed the two capacitors that went to ground and now my sound quality is fantastic!
#130
Thanks.
Thanks.
If you have some doubts about the quality of your connection, use a multimeter in continuity mode and check if all your connections are continuous.
