Better Bluetooth Streaming
I was using a USB stick style bluetooth that plugged into my rear console aux line. This was "sufficient" until my 6 year old snapped it in half while sitting in the middle seat.:(
Not to be dissuaded, I looked for a more "integrated" solution. Enter the Pure Electronics Bluetooth receiver. Full 2.1 + EDR bluetooth with the APTx codec means high quality audio. 12volt input makes for easy hookup with no messing around with power adaptors or any other nonsense. https://images-na.ssl-images-amazon....AC_SL1500_.jpg So using Roskinc's great disassembly videos I yanked out my rear center console panel which already had the two cigarette lighter jacks and the aux jack factory installed. https://cimg4.ibsrv.net/gimg/5series...572e9896f0.jpg After pulling this, I got busy with the soldering iron. https://cimg1.ibsrv.net/gimg/5series...6be39c9e9e.jpg First step was wiring 12v to one of the cigarette lighters. This is easy as you can solder directly from the bluetooth receiver PCB to a couple of points on the cigaretter lighter housing with only a few inches of wire in between. Then I had to crack open the AUX module and using a meter to determine what was left channel, right channel and ground, soldered in some scrap RCA cables and drilled a hole out the back of the module so the RCAs could jack directly into my shiny new Bluetooth receiver. Finished up by mounting the PCB to the top of the AUX module with a little double sided tape and... https://cimg6.ibsrv.net/gimg/5series...4032c9abc3.jpg Next step is to take that new assembly and wire it up to the car. https://cimg2.ibsrv.net/gimg/5series...3c1df6fdf1.jpg https://cimg3.ibsrv.net/gimg/5series...6c3dbe4e0f.jpg Then snap the cover back in. Yes that's the same pic as the before picture. Point being that externally, there's nothing to see here. Super clean, super stock. https://cimg4.ibsrv.net/gimg/5series...572e9896f0.jpg Turn on the car, pair it up with your phone... Then you're in business! The verdict: At $20 this bluetooth module is a STEAL. Sound quality is excellent! And the convenience of not needing a stupid cable into AUX is amazing! I picked up my Bluetooth receiver by Pure Electronics on eBay from a seller named Curious Provisions but you can pick up the same module from when they get them back in stock. |
Do you have any hum or feedback from the sound system while the engine is running? The problem that I've found with powered Bluetooth adapters (or iPhone adapters) is that I always hear a whine or hum while the engine is running.
Also, how did you mount the BT module to the panel? |
Originally Posted by txag_530i
(Post 1549684)
(Post 1549684)
Looks good.
Follow up:
So after living with this BT receiver for a couple weeks I found that it doesn't seek out and auto connect like other BT items do. I can assume this is by design. To get around this I installed an automation app called "Trigger" on my phone and set up some jobs. First job, called "Start BMW audio" waits for my car's phone BT to connect then does a force connection to the BT audio receiver. This is the equivalent to going in to your BT settings and doing a "pairing." After that, it continues the job by starting up Pandora. So I basically get in the car, start it and the music will start playing in a few moments after connections are established. Using the same app, I do the opposite when leaving the car by forcing a BT disconnect and a shutdown of the Pandora app. The great thing about doing some automation like this is that you can have it do all kinds of things to your phone like setting brightness, launching certain apps, sending messages, whatever you want to do. Give it a try!;) |
Would you happen to know if this rcvr would work with the older TCU in my 10/2003 built 545.?
Originally Posted by cmyachtie
(Post 1550148)
(Post 1550148)
So now the question arises... how much for you to make more? :) I want one but I dont have the patience to solder and seek which wires go to where. :(
+1
| All times are GMT -8. The time now is 07:37 PM. |
