any Verizon XV6700 phonebook fixes?
My Ride: silver-gray 525i w/ nav, pdc, xenon, and comfort access
I read a post in March of this year that said the XV6700 does not transfer the phonebook over bluetooth. I have MY07 525i with an August build date but am not sure if the current software supports the phone. Has anyone gotten it to work flawlessly? Thanks in advance.
My Ride: 2003 E39 M5 -- Fully loaded
I have it working flawlessly. Using a software program jetwaremobile. Transfers phone and signal icons. works flawlessly. set your phone to not turn off when bluetooth is on, I do this by plugging phone into socket. under power options, set when plugged in, 0 timeout. Will keep bluetooth active. no problems encountered in 2 months of use.
Full transfer of phonebook and missed/received/sent calls/Top 8/redial calls also!!!
