Another Bluetooth question
Old Feb 23, 2005 | 05:19 PM
hinckley's Avatar
With an incoming call, the radio mutes, but there is no ring through the car's speakers (although the phone itself rings). It's kind of weird - all of a sudden the radio mutes and I look down and there's a call showing on the iDrive screen. Is there a way to have the phone ring through the speakers?
Also, is there a way to have a private conversation using the phone itself rahter than always sending calls thru the speakers?
Old Feb 24, 2005 | 08:34 PM
Hormazd's Avatar
Originally Posted by hinckley' date='Feb 23 2005, 06:19 PM
With an incoming call, the radio mutes, but there is no ring through the car's speakers (although the phone itself rings).? It's kind of weird - all of a sudden the radio mutes and I look down and there's a call showing on the iDrive screen.? Is there a way to have the phone ring through the speakers?
[snapback]93710[/snapback]
The private conversation is possible but not very practical. It envolves dropping the connection from the phone which is a lenghty process unless you can create short cuts on your phone.
Your ringing problem maybe related to your phone settings. Do you have it set to Vibrate or to silent. if not then when you say "call showing through I-drive"
do you mean an active call? If so then your phone is set to auto answer on handsfree. look through the handsfree or car settings and make sute it is not set to auto answer. Then you will hear you phone ring and I-drive will show you the incoming call with the option to accept or reject. You can accept using the phone button on the steering wheel.
Old Feb 25, 2005 | 02:24 AM
hinckley's Avatar
Originally Posted by Hormazd' date='Feb 25 2005, 12:34 AM
[quote name='hinckley' date='Feb 23 2005, 06:19 PM']With an incoming call, the radio mutes, but there is no ring through the car's speakers (although the phone itself rings).? It's kind of weird - all of a sudden the radio mutes and I look down and there's a call showing on the iDrive screen.? Is there a way to have the phone ring through the speakers?
[snapback]94156[/snapback]
[/quote]
Thanks. I understand what needs to be done for a private call and the shortcut may be a pretty easy solution.
On the second issue, my phone is set to ring (not to silent or vibrate) and iDrive does ask to me accept or reject the call - but I know to look down to accept or reject because the radio has muted, not because I've heard a ring. Strange . . .
predshaw
13
Nov 22, 2021 05:58 AM
zukgod1
Jul 14, 2015 10:19 PM
525d MSport
F10 Discussion
Jul 12, 2015 07:03 AM
w84me
Jul 10, 2015 10:56 AM
ST JAMES
Jul 3, 2015 07:04 PM
