2004 e60 bluetooth %100 fix, solution
2 months ago I bought 2004 e60 (03/25/2004 production),
After check the VIN I saw it has bluetooth option but it is not in iDrive and story started.
for two months I started to research to how to enable I think I checked %90 online forums.
I had no idea about the coding the car. Then I bought the cable, DIS, TIS, SSS/GT1, INPA,Ncsexpert, NCSdummy. I can't use SSS (Wmware problems).
I started with INPA (I learned it just for Diag and clear error codes.)
Then I start the using NCSexpert and NCSDummy (I suggest, they are perfect tools, if you know how to use it.)
Now,
if you have TCU with BT function,
if you cannot see BT option in iDrive,
if you see BT option but cannot pair with phone,
if you pair phone but can't make call,
if you pair phone and make call but your voice is not going to them,
if you pair and can make call but the car can not get your phone list,
follow me. you are not alone![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
my TCU ( 84116948921 )
1) Enable BT in MASK,
2) set you TCUM module options same as mine.
VR_EQUIPPED -- it seems not working.
aktiv
TRACK_WIDTH
e60_e61
WHEEL_CIRCUMFERENCE
e60_e61
m5
WHEEL_BASE
e60
SCS_OR_SVS
scs
DSP_ACOUSTIC_PROFILE
wert_01
NAD_EQUIPPED
aktiv
DRIVE_WHEELS
rear_wheel
DELAY_PWR_DOWN_INIT_DUR
wert_00
TWO_MICROPHONES --- if others can't hear you set wert_02
wert_01
SIM_IN_TELEMATIK_READER
aktiv
TELEMATIK_SIM_ENABLED
aktiv
SPRACHE
us
US_BUSINESS/PROF_VARIANT
business_model
AIRBAG_TRIGGERED_E-CALL
aktiv
E-CALL_CHECK_CONTROL
nicht_aktiv
WAKE-UP_BY_E-CALL
aktiv
CUSTOMER_CALLS_OVER_GMIN
aktiv
E-CALL_HARDKEY_FITTED -- enables phone button on steering wheel.
aktiv
NON-TELEMATIC_E-CALL
aktiv
MOST_ASYNC_OR_CTRL_CHANNL
most_control_channel
TCU_TYPE
e60_us
TIMER_SMS_NACK
wert_02
BLUETOOTH ---important
aktiv
E_CALL_COUNTD_DELAY_TIMER
wert_02
BACKUP_ANTENNA
aktiv
GPS_ON/OFF
aktiv
TELEMATIK_ENABLED
aktiv
BACKUP_LOUDSPEAKER
aktiv
PORTABLE_BT -- important
aktiv
ACK_2_AIRBAG
aktiv
ALIVE_SIGNAL
nicht_aktiv
CAS_KEY_DATA_METHOD
wert_01
AKIRA_MEMS/GATS
gats
PAY_TMC_CONTROL
nicht_aktiv
GATS_SMS_DESTIN_BACKUP
wireless_car_prod
GATS_SMS_DESTIN_DEFAULT --- important if you can pair but can't make call.
wireless_car_prod
GATS_SMSC_OR_AMPS_BACKUP
atxeu_preprod_d1
wireless_car_prod
GATS_SMSC_OR_AMPS_DFLT important if you can pair but can't make call.
atxeu_preprod_d1
wireless_car_prod
NON_TELEMATIC_E_CALL_NR
nummer2
RDU_CONTROL
nicht_aktiv
SVR_CONTROL
aktiv
PHONEBOOK_PRIORITY ---- important if you can pair but car can't read phone book..
wert_01
Now,
aktiv
TRACK_WIDTH
e60_e61
WHEEL_CIRCUMFERENCE
e60_e61
m5
WHEEL_BASE
e60
SCS_OR_SVS
scs
wert_01
NAD_EQUIPPED
aktiv
DRIVE_WHEELS
rear_wheel
wert_00
wert_01
aktiv
aktiv
SPRACHE
us
business_model
aktiv
nicht_aktiv
WAKE-UP_BY_E-CALL
aktiv
aktiv
aktiv
aktiv
TCU_TYPE
e60_us
TIMER_SMS_NACK
wert_02
aktiv
wert_02
BACKUP_ANTENNA
aktiv
GPS_ON/OFF
aktiv
TELEMATIK_ENABLED
aktiv
BACKUP_LOUDSPEAKER
aktiv
aktiv
ACK_2_AIRBAG
aktiv
ALIVE_SIGNAL
nicht_aktiv
CAS_KEY_DATA_METHOD
wert_01
AKIRA_MEMS/GATS
gats
PAY_TMC_CONTROL
nicht_aktiv
wireless_car_prod
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
nummer2
RDU_CONTROL
nicht_aktiv
SVR_CONTROL
aktiv
wert_01
and my mask trace;
K931D_ZV_ALLE_TUEREN
par_frei
K931D_ZV_SELEKTIV
par_frei
K930E_ZV_VER_N_XMIN_FB
fkt_frei
K9901_WARNBLINKEN
par_gesperrt
K9323_ZV_VER_AB_X_KM/H
fkt_frei
K8129_ZWAKO_AC_EIN_AUTO
fkt_gesperrt
K7504_HEIMLEUCHTEN_AUS
par_frei
K7504_HEIMLEUCHTEN_40S
par_frei
K7504_HEIMLEUCHTEN_90S
par_frei
K7504_HEIMLEUCHTEN_150S
par_frei
K7504_HEIMLEUCHTEN_240S
par_frei
K4328_BLINKEN_TIPPBET
fkt_frei
K5303_GAL_SEHR_STARK
par_frei
K8116_KLAPPENAUTOMATIK
fkt_gesperrt
K5303_GAL_STARK
par_frei
K5303_GAL_MITTEL
par_frei
K5303_GAL_GERING
par_frei
K5303_GAL_SEHR_GERING
par_frei
K5303_GAL_KEINE_ANHEB
par_frei
K5305_KLANG_BASS
par_frei
K5305_KLANG_TREBLE
par_frei
K5305_KLANG_BALANCE
par_frei
K5305_KLANG_FADER
par_frei
K5305_KLANG_REVERB
par_frei
K5305_KLANG_EQULIZER
par_frei
K531A_LAUTST_NAV
par_frei
K531A_LAUTST_VERKEHR
par_frei
K531A_LAUTST_TELEFON
par_frei
K531A_LAUTST_SVS
par_frei
K531A_LAUTST_PDC
par_frei
K4310_ANZ_SPRACHE_1
par_frei
K4310_ANZ_SPRACHE_2
par_frei
K4310_ANZ_SPRACHE_3
par_frei
K4110_VERBR_L/100KM
par_frei
K4110_VERBR_MPG_US
par_frei
K4110_VERBR_MPG_UK
par_frei
K4110_VERBR_KM/L
par_frei
K410D_EINHEITEN_WEG
fkt_frei
K4113_ZEIT_STD_DARST
fkt_frei
K4116_EINH_TEMPERATUR
fkt_frei
K9901_UMLUFT_EIN
par_frei
K9901_NAV_LETZER_HINWEIS
par_frei
K9901_KOMFORT_PARKBREMSE
par_frei
K9901_MUTE_EIN
par_frei
K9901_MONITOR_EIN
par_frei
K9901_LENKRADHEIZUNG
par_frei
K9901_RADIO/TELEFON
par_frei
K9901_SWR
par_gesperrt
K430C_DATUM_FORMAT
fkt_frei
C750A_SCHWELLWERT_EMPFIN
par_gesperrt
C750A_SCHWELLWERT_NORMAL
par_gesperrt
C750A_SCHWELLWERT_SEHR_E
par_gesperrt
DRUCK_EINHEIT
psi
K8601_SOLLWERT_M3
par_gesperrt
K8601_SOLLWERT_M2
par_gesperrt
K8601_SOLLWERT_M1
par_gesperrt
K8601_SOLLWERT_0
par_gesperrt
K8601_SOLLWERT_P1
par_gesperrt
K8601_SOLLWERT_P2
par_gesperrt
K8601_SOLLWERT_P3
par_gesperrt
K4D01_OFF_CID_DISPL_HELL
fkt_frei
BLUETOOTH_FIX
aktiv
K4119_DRUCK_BAR
par_frei
K4119_DRUCK_PSI
par_frei
K4119_DRUCK_KPA
par_frei
K8313_GEBLAESE_M10
par_gesperrt
K8313_GEBLAESE_0
par_gesperrt
K8313_GEBLAESE_P10
par_gesperrt
K9901_HUPE
par_gesperrt
PHONE_MULF
nicht_aktiv
C940C_QUITT_OPT_ENTSCH
fkt_gesperrt
C940D_QUITT_OPT_SCHAERF
fkt_gesperrt
C940A_QUITT_OPT_ENTSCH
fkt_frei
C9419_QUITT_OPT_KLAPPE
fkt_frei
C9410_QUITT_OPT_SCHAERF
fkt_frei
C941C_QUITT_AKUST_KLAPPE
fkt_frei
K9416_QUITT_AKUST_ENTSCH
fkt_frei
C9413_QUITT_AKUST_SCHAERF
fkt_frei
K8119_PRG_AUTOMATIK
par_gesperrt
K8119_PRG_LUFTVERTEILUNG
par_gesperrt
K8127_KLAPPENPROGRAMM_BO
fkt_frei
K8119_PRG_GEBL_AKTUELL
par_gesperrt
K8119_PRG_SCHICHTUNG
par_gesperrt
K8119_PRG_AC
par_gesperrt
K8125_KLAPPENPROGRAMM_BO
fkt_frei
K532F_SENDERLISTE_AUDIO
fkt_gesperrt
K4D01_OFF_HUD_DISPL_HELL
fkt_gesperrt
K4D03_ANZEIGE_GESCHWNDGKT
par_gesperrt
K4D03_ANZEIGE_CHECKCONTRL
par_gesperrt
K4D03_ANZEIGE_ACC
par_gesperrt
K4D03_ANZEIGE_TEMPOMAT
par_gesperrt
K4D03_ANZEIGE_NAVIGATION
par_gesperrt
K2407_PDC_MONITORBILD
fkt_gesperrt
CA107_AUT_VERST_DEAKT
par_frei
CA107_AUT_VERST_ENTR
par_frei
CA107_AUT_VERST_ENT_T
par_frei
C9C03_KLAPPENWINKEL
fkt_gesperrt
C9C01_HKL_TASTE
fkt_gesperrt
K931D_SCHEIBENABSENKUNG
par_gesperrt
NIVI
nicht_aktiv
VOLUME_MAXIMUM_TEL
e70
e91
max2
standard
VOLUME_MAXIMUM_ON
e92_stereo
max1
standard
VOLUME_AUDIO_1
e60
e70_stereo
e92_hifi
e93_hifi
VOLUME_MINIMUM_NAVI
e92_stereo
max1
standard
VOLUME_DELTA_NAVI_ENTER
e92_stereo
min3
standard
VOLUME_MINIMUM_TM
e70_stereo
e92_hifi
e92_stereo
e93_hifi
min1
standard
VOLUME_MINIMUM_TEL
e92_stereo
min1
standard
VOLUME_DELTA_TEL_ENTER
e70_stereo
e92_hifi
e92_stereo
e93_hifi
max1
standard
VOLUME_KLANG_1
e60_hifi
e61_hifi
KLANG_OFFSET
e70_stereo
e92_hifi
e92_stereo
e93_hifi
e93_stereo
min1
standard
VOLUME_PDC
e60_hifi
e63_hifi
e64_hifi
e70_hifi
e82_top_hifi
e92_stereo
max2
VOLUME_DELTA_PDC_ENTER
e87_stereo
max2
standard
VOLUME_SECUR_1
e60
e70_stereo
e87
e92_hifi
e92_stereo
e93_hifi
LOUDNESS
e60
GAL_MAIN
e60
GAL_DEFAULT
e60
MUTE_ON_CRASH
nicht_aktiv
KEY_MEMORY_ASK
aktiv
MUTEMIX_TIME
e60
pl2
DAUER
e60
pl2
ABSTAND_IDENT_PRIO
e60
pl2
NACHLAUF_INT
e60
pl2
TIMEOUT_INT
e60
pl2
HIGH_CUT
auto
EINH_MASTER
aktiv
VOLUME_MINIMUM_SPEECH
e92_stereo
min1
standard
AUDIO_ENTERTAIN_1
us
LUEFTER_SCHW1
e60
pl2
LUEFTER_SCHW2
e60
pl2
LUEFTER_WERT1
e60
pl2
LUEFTER_WERT2
e60
pl2
LUEFTER_WERT3
e60
pl2
LUEFTER_WERT4
e60
pl2
SINGLE_TUNER
aktiv
DOUBLE_TUNER
nicht_aktiv
CDC
nicht_aktiv
MMC
nicht_aktiv
TOP_HIFI
nicht_aktiv
EQUALIZER
aktiv
VOLUME_ADJ_1
e60_hifi
e61_hifi
e63_hifi
VOLUME_ADJ_2
e60_hifi
e61_hifi
e63_hifi
VOLUME_ADJ_3
e60_hifi
e61_hifi
e63_hifi
VOLUME_ADJ_4
e60_hifi
e61_hifi
e63_hifi
SDARS
nicht_aktiv
SITZHEIZUNG
aktiv
ECE_TELEFON
nicht_aktiv
PHONE_BUSINESS
aktiv
PHONE_PROF
aktiv
BMW_ASSIST
aktiv
HELPNET
nicht_aktiv
BMW_ONLINE
aktiv
PDC
nicht_aktiv
ABSENK_ENTERTAINMENT_PDC
e70
e87_hifi
e87_stereo
ein
SHOW_PDC
nicht_aktiv
RDC
nicht_aktiv
HUD
nicht_aktiv
ELDRVSEAT
aktiv
MFL_HORN
nicht_aktiv
MFL_HAZARD
nicht_aktiv
MFL_CLEAN
nicht_aktiv
FOND_LOW
nicht_aktiv
LAENDERVARIANTE_TUNER
us
RDS_AF_FUNKTION
rds_ein_af_aus
TP_FUNKTION
tp
TP
nicht_aktiv
TMC
nicht_aktiv
AMBANDS
aktiv
FILTER_FZG_BLOCK_1
e60_hifi
FILTER_FZG_BLOCK_2
e60_hifi
FILTER_FZG_BLOCK_3
e60_hifi
FILTER_FZG_BLOCK_4
e60_hifi
PHASE_BLOCK
e60_flat
e60_hifi
e70_hifi
e70_stereo
e82_stereo
e87_hifi
e87_stereo_old
e88_stereo
e90_hifi
e90_stereo
e91_stereo
e92_hifi
e93_hifi
pl2_hifi
CROSS_OVER_1
e60_hifi
e70_hifi
CROSS_OVER_2
e60_hifi
e70_hifi
OUTPUT_GAIN_SYSTEM
e60_hifi
e70_hifi
BAUREIHE
e60
CODIERUNG_ERFOLGT
codierung_erfolgt
TYP_LENKUNG
linkslenker
OUTPUT_SIGNAL_TABLE_1
e60_ll
e60_rl
e70_ll
e70_rl
pl2_ll
pl2_rl
OUTPUT_SIGNAL_TABLE_2
e60_ll
e60_rl
e70_ll
e70_rl
pl2_ll
pl2_rl
ACC
nicht_aktiv
CRUISE_CTRL
aktiv
WAEHLBARE_SPRACHE_1
us
WAEHLBARE_SPRACHE_2
us
WAEHLBARE_SPRACHE_3
us
CID
cid_mid
RING
aktiv
WEG_EINHEIT
mls
BC_HIGH
aktiv
KLIMA_SG_ART
high
STANDLUFT
aktiv
DWS
aktiv
BMW_N_DEALER
aktiv
TRF
nicht_aktiv
KANA_WRITER
nicht_aktiv
SMS
aktiv
PTY_TABELLE
pty_us
WEATHERBAND
aktiv
LEGAL_DISCL
nicht_aktiv
REV_INPUT
aktiv
UNIT_FEET
aktiv
ACOUSTIC
aktiv
REGIONALISIERUNG
reg_aus
TEMPERATUR_EINHEIT
grad_f
ZEIT_EINHEIT
12_stunden
DATUM_EINHEIT
mm_tt_jj
SPEECH_MF
weiblich
VERBRAUCH
mpg
BACKDOOR
nicht_aktiv
E64
nicht_aktiv
STANDHEIZUNG
aktiv
AUXIN
aktiv
FLAP
nicht_aktiv
PDC_LOW
nicht_aktiv
VOLUME_KLANG_EMERGENCY
e60_hifi
e70_hifi
e90_hifi
e91_hifi
VOLUME_PDC_EMERGENCY
e60_hifi
e63_hifi
e64_hifi
e87_hifi
e87_stereo
SVS_LOW
nicht_aktiv
GALLON_VAL
us
MP3
aktiv
AMBAND_KW
aktiv
AMBAND_LW
aktiv
AMBAND_MW
aktiv
OIL_LEVEL
aktiv
NAVIGATION_MASK
aktiv
CBS_MODE
level_3
PIA_LEVEL
level_1
SENDER_TAB_HGL
nicht_aktiv
AUTO_DRV_LIGHT
nicht_aktiv
HDC
nicht_aktiv
MDRIVE
nicht_aktiv
MDRIVE_ALBV
nicht_aktiv
MDRIVE_SMG
aktiv
VA_BPI
nicht_aktiv
AUDIO_SYSTEM_MASK
e60_hifi
e90_hifi
pl2_hifi
DISPLAY_LOG7_SYMBOL
aktiv
NAVIGATION_FLOTTENMODUS
nicht_aktiv
MP3CDC
aktiv
NEUSEELAND
nicht_aktiv
BLUETOOTH_NODES_MASK
profil_2
BMW_DEALER_MASK
aktiv
BMW_HOTLINE_MASK
aktiv
BMW_MOBILE_MASK
aktiv
DAB
nicht_aktiv
DAB_BAND_SETTINGS
nicht_aktiv
DAB_FM_SWITCH
nicht_aktiv
DAY_RUN_LIGHT_MASK
aktiv
IBOC
nicht_aktiv
CODIER_CHECK
aktiv
LOGISTIK_CHECK
aktiv
DSC_IN_MDRIVE
nicht_aktiv
FBM_COMMUNICATION
nicht_aktiv
FBM_ENTERTAINMENT
nicht_aktiv
FBM_FMAM_TOGGLE
nicht_aktiv
FBM_MODE_TOGGLE
nicht_aktiv
FBM_NAVIGATION
nicht_aktiv
FBMS
nicht_vorhanden
HANGUL_TYPEWRITER
nicht_aktiv
KANJI_TYPEWRITER
nicht_aktiv
MOST_ASYNC_CTRL_CHANNL
RAMP_CONTROL
nicht_aktiv
SEATVENTILATION
nicht_aktiv
SITZHEIZUNG_SLIDER
nicht_aktiv
FOND_MID
nicht_aktiv
LAST_PANEL_TIMEOUT
e6x
e70
e89
LEGAL_DISCL_TIMEOUT
e6x
e70
e89
MANUAL_SHIFT
nicht_aktiv
NOAIRVENT_FINE
nicht_aktiv
CAR_COLOR_CHAMP
nicht_aktiv
par_frei
K931D_ZV_SELEKTIV
par_frei
fkt_frei
K9901_WARNBLINKEN
par_gesperrt
fkt_frei
fkt_gesperrt
par_frei
par_frei
par_frei
par_frei
par_frei
fkt_frei
par_frei
fkt_gesperrt
K5303_GAL_STARK
par_frei
K5303_GAL_MITTEL
par_frei
K5303_GAL_GERING
par_frei
par_frei
par_frei
K5305_KLANG_BASS
par_frei
K5305_KLANG_TREBLE
par_frei
K5305_KLANG_BALANCE
par_frei
K5305_KLANG_FADER
par_frei
K5305_KLANG_REVERB
par_frei
par_frei
K531A_LAUTST_NAV
par_frei
par_frei
par_frei
K531A_LAUTST_SVS
par_frei
K531A_LAUTST_PDC
par_frei
K4310_ANZ_SPRACHE_1
par_frei
K4310_ANZ_SPRACHE_2
par_frei
K4310_ANZ_SPRACHE_3
par_frei
K4110_VERBR_L/100KM
par_frei
K4110_VERBR_MPG_US
par_frei
K4110_VERBR_MPG_UK
par_frei
K4110_VERBR_KM/L
par_frei
K410D_EINHEITEN_WEG
fkt_frei
fkt_frei
fkt_frei
K9901_UMLUFT_EIN
par_frei
par_frei
par_frei
K9901_MUTE_EIN
par_frei
K9901_MONITOR_EIN
par_frei
par_frei
K9901_RADIO/TELEFON
par_frei
K9901_SWR
par_gesperrt
K430C_DATUM_FORMAT
fkt_frei
par_gesperrt
par_gesperrt
par_gesperrt
DRUCK_EINHEIT
psi
K8601_SOLLWERT_M3
par_gesperrt
K8601_SOLLWERT_M2
par_gesperrt
K8601_SOLLWERT_M1
par_gesperrt
K8601_SOLLWERT_0
par_gesperrt
K8601_SOLLWERT_P1
par_gesperrt
K8601_SOLLWERT_P2
par_gesperrt
K8601_SOLLWERT_P3
par_gesperrt
fkt_frei
BLUETOOTH_FIX
aktiv
K4119_DRUCK_BAR
par_frei
K4119_DRUCK_PSI
par_frei
K4119_DRUCK_KPA
par_frei
K8313_GEBLAESE_M10
par_gesperrt
K8313_GEBLAESE_0
par_gesperrt
K8313_GEBLAESE_P10
par_gesperrt
K9901_HUPE
par_gesperrt
PHONE_MULF
nicht_aktiv
fkt_gesperrt
fkt_gesperrt
fkt_frei
fkt_frei
fkt_frei
fkt_frei
fkt_frei
fkt_frei
K8119_PRG_AUTOMATIK
par_gesperrt
par_gesperrt
fkt_frei
par_gesperrt
par_gesperrt
K8119_PRG_AC
par_gesperrt
fkt_frei
fkt_gesperrt
fkt_gesperrt
par_gesperrt
par_gesperrt
K4D03_ANZEIGE_ACC
par_gesperrt
par_gesperrt
par_gesperrt
fkt_gesperrt
par_frei
par_frei
par_frei
C9C03_KLAPPENWINKEL
fkt_gesperrt
C9C01_HKL_TASTE
fkt_gesperrt
par_gesperrt
NIVI
nicht_aktiv
VOLUME_MAXIMUM_TEL
e70
e91
max2
standard
VOLUME_MAXIMUM_ON
e92_stereo
max1
standard
VOLUME_AUDIO_1
e60
e70_stereo
e92_hifi
e93_hifi
VOLUME_MINIMUM_NAVI
e92_stereo
max1
standard
e92_stereo
min3
standard
VOLUME_MINIMUM_TM
e70_stereo
e92_hifi
e92_stereo
e93_hifi
min1
standard
VOLUME_MINIMUM_TEL
e92_stereo
min1
standard
e70_stereo
e92_hifi
e92_stereo
e93_hifi
max1
standard
VOLUME_KLANG_1
e60_hifi
e61_hifi
KLANG_OFFSET
e70_stereo
e92_hifi
e92_stereo
e93_hifi
e93_stereo
min1
standard
VOLUME_PDC
e60_hifi
e63_hifi
e64_hifi
e70_hifi
e82_top_hifi
e92_stereo
max2
e87_stereo
max2
standard
VOLUME_SECUR_1
e60
e70_stereo
e87
e92_hifi
e92_stereo
e93_hifi
LOUDNESS
e60
GAL_MAIN
e60
GAL_DEFAULT
e60
MUTE_ON_CRASH
nicht_aktiv
KEY_MEMORY_ASK
aktiv
MUTEMIX_TIME
e60
pl2
DAUER
e60
pl2
ABSTAND_IDENT_PRIO
e60
pl2
NACHLAUF_INT
e60
pl2
TIMEOUT_INT
e60
pl2
HIGH_CUT
auto
EINH_MASTER
aktiv
e92_stereo
min1
standard
AUDIO_ENTERTAIN_1
us
LUEFTER_SCHW1
e60
pl2
LUEFTER_SCHW2
e60
pl2
LUEFTER_WERT1
e60
pl2
LUEFTER_WERT2
e60
pl2
LUEFTER_WERT3
e60
pl2
LUEFTER_WERT4
e60
pl2
SINGLE_TUNER
aktiv
DOUBLE_TUNER
nicht_aktiv
CDC
nicht_aktiv
MMC
nicht_aktiv
TOP_HIFI
nicht_aktiv
EQUALIZER
aktiv
VOLUME_ADJ_1
e60_hifi
e61_hifi
e63_hifi
VOLUME_ADJ_2
e60_hifi
e61_hifi
e63_hifi
VOLUME_ADJ_3
e60_hifi
e61_hifi
e63_hifi
VOLUME_ADJ_4
e60_hifi
e61_hifi
e63_hifi
SDARS
nicht_aktiv
SITZHEIZUNG
aktiv
ECE_TELEFON
nicht_aktiv
PHONE_BUSINESS
aktiv
PHONE_PROF
aktiv
BMW_ASSIST
aktiv
HELPNET
nicht_aktiv
BMW_ONLINE
aktiv
PDC
nicht_aktiv
e70
e87_hifi
e87_stereo
ein
SHOW_PDC
nicht_aktiv
RDC
nicht_aktiv
HUD
nicht_aktiv
ELDRVSEAT
aktiv
MFL_HORN
nicht_aktiv
MFL_HAZARD
nicht_aktiv
MFL_CLEAN
nicht_aktiv
FOND_LOW
nicht_aktiv
us
RDS_AF_FUNKTION
rds_ein_af_aus
TP_FUNKTION
tp
TP
nicht_aktiv
TMC
nicht_aktiv
AMBANDS
aktiv
FILTER_FZG_BLOCK_1
e60_hifi
FILTER_FZG_BLOCK_2
e60_hifi
FILTER_FZG_BLOCK_3
e60_hifi
FILTER_FZG_BLOCK_4
e60_hifi
PHASE_BLOCK
e60_flat
e60_hifi
e70_hifi
e70_stereo
e82_stereo
e87_hifi
e87_stereo_old
e88_stereo
e90_hifi
e90_stereo
e91_stereo
e92_hifi
e93_hifi
pl2_hifi
CROSS_OVER_1
e60_hifi
e70_hifi
CROSS_OVER_2
e60_hifi
e70_hifi
OUTPUT_GAIN_SYSTEM
e60_hifi
e70_hifi
BAUREIHE
e60
CODIERUNG_ERFOLGT
codierung_erfolgt
TYP_LENKUNG
linkslenker
e60_ll
e60_rl
e70_ll
e70_rl
pl2_ll
pl2_rl
e60_ll
e60_rl
e70_ll
e70_rl
pl2_ll
pl2_rl
ACC
nicht_aktiv
CRUISE_CTRL
aktiv
WAEHLBARE_SPRACHE_1
us
WAEHLBARE_SPRACHE_2
us
WAEHLBARE_SPRACHE_3
us
CID
cid_mid
RING
aktiv
WEG_EINHEIT
mls
BC_HIGH
aktiv
KLIMA_SG_ART
high
STANDLUFT
aktiv
DWS
aktiv
BMW_N_DEALER
aktiv
TRF
nicht_aktiv
KANA_WRITER
nicht_aktiv
SMS
aktiv
PTY_TABELLE
pty_us
WEATHERBAND
aktiv
LEGAL_DISCL
nicht_aktiv
REV_INPUT
aktiv
UNIT_FEET
aktiv
ACOUSTIC
aktiv
REGIONALISIERUNG
reg_aus
TEMPERATUR_EINHEIT
grad_f
ZEIT_EINHEIT
12_stunden
DATUM_EINHEIT
mm_tt_jj
SPEECH_MF
weiblich
VERBRAUCH
mpg
BACKDOOR
nicht_aktiv
E64
nicht_aktiv
STANDHEIZUNG
aktiv
AUXIN
aktiv
FLAP
nicht_aktiv
PDC_LOW
nicht_aktiv
e60_hifi
e70_hifi
e90_hifi
e91_hifi
e60_hifi
e63_hifi
e64_hifi
e87_hifi
e87_stereo
SVS_LOW
nicht_aktiv
GALLON_VAL
us
MP3
aktiv
AMBAND_KW
aktiv
AMBAND_LW
aktiv
AMBAND_MW
aktiv
OIL_LEVEL
aktiv
NAVIGATION_MASK
aktiv
CBS_MODE
level_3
PIA_LEVEL
level_1
SENDER_TAB_HGL
nicht_aktiv
AUTO_DRV_LIGHT
nicht_aktiv
HDC
nicht_aktiv
MDRIVE
nicht_aktiv
MDRIVE_ALBV
nicht_aktiv
MDRIVE_SMG
aktiv
VA_BPI
nicht_aktiv
AUDIO_SYSTEM_MASK
e60_hifi
e90_hifi
pl2_hifi
DISPLAY_LOG7_SYMBOL
aktiv
nicht_aktiv
MP3CDC
aktiv
NEUSEELAND
nicht_aktiv
profil_2
BMW_DEALER_MASK
aktiv
BMW_HOTLINE_MASK
aktiv
BMW_MOBILE_MASK
aktiv
DAB
nicht_aktiv
DAB_BAND_SETTINGS
nicht_aktiv
DAB_FM_SWITCH
nicht_aktiv
DAY_RUN_LIGHT_MASK
aktiv
IBOC
nicht_aktiv
CODIER_CHECK
aktiv
LOGISTIK_CHECK
aktiv
DSC_IN_MDRIVE
nicht_aktiv
FBM_COMMUNICATION
nicht_aktiv
FBM_ENTERTAINMENT
nicht_aktiv
FBM_FMAM_TOGGLE
nicht_aktiv
FBM_MODE_TOGGLE
nicht_aktiv
FBM_NAVIGATION
nicht_aktiv
FBMS
nicht_vorhanden
HANGUL_TYPEWRITER
nicht_aktiv
KANJI_TYPEWRITER
nicht_aktiv
RAMP_CONTROL
nicht_aktiv
SEATVENTILATION
nicht_aktiv
SITZHEIZUNG_SLIDER
nicht_aktiv
FOND_MID
nicht_aktiv
LAST_PANEL_TIMEOUT
e6x
e70
e89
LEGAL_DISCL_TIMEOUT
e6x
e70
e89
MANUAL_SHIFT
nicht_aktiv
NOAIRVENT_FINE
nicht_aktiv
CAR_COLOR_CHAMP
nicht_aktiv
2004 545i
That's exactly what I been looking for months. Do you have to make change to all lines you have listed? If not, can you summaries just the ones that need to be change? I will get my cable/program in couple of weeks.
BLUETOOTH_FIX
aktiv
PHONE_MULF
nicht_aktiv
ECE_TELEFON
nicht_aktiv
PHONE_BUSINESS
aktiv
PHONE_PROF
aktiv
BMW_ASSIST
aktiv
HELPNET
nicht_aktiv
BMW_ONLINE
aktiv
RING
aktiv
SMS
aktiv
BLUETOOTH_NODES_MASK // if can't upload phone book try other options
profil_2
BMW_DEALER_MASK
aktiv
BMW_HOTLINE_MASK
aktiv
BMW_MOBILE_MASK
aktiv
BMW_N_DEALER
aktiv
IBOC
nicht_aktiv
TCUM Unit
wert_01
aktiv
aktiv
SPRACHE
us
business_model
aktiv
nicht_aktiv
WAKE-UP_BY_E-CALL
aktiv
aktiv
aktiv
aktiv
TCU_TYPE
e60_us
TIMER_SMS_NACK
wert_02
aktiv
wert_02
BACKUP_ANTENNA
aktiv
TELEMATIK_ENABLED
aktiv
aktiv
wireless_car_prod
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
PHONEBOOK_PRIORITY ---- important if you can pair but car can't read phone book.. if not work try other options.
wert_01
Thanks
Any chance you could also post the VO, I have added +K633 and tried also with +TELD but neither one of any combinations is working for me, all is working EXCEPT the callers cannot hear me.....
Also have the refitted 2005 TCU version installed by dealer years ago and since I bought the car BT was not enabled .
Good stuff
My Ride: E60
Now,
aktiv
TRACK_WIDTH
e60_e61
WHEEL_CIRCUMFERENCE
e60_e61
m5
WHEEL_BASE
e60
SCS_OR_SVS
scs
wert_01
NAD_EQUIPPED
aktiv
DRIVE_WHEELS
rear_wheel
wert_00
wert_01
aktiv
aktiv
SPRACHE
us
business_model
aktiv
nicht_aktiv
WAKE-UP_BY_E-CALL
aktiv
aktiv
aktiv
aktiv
TCU_TYPE
e60_us
TIMER_SMS_NACK
wert_02
aktiv
wert_02
BACKUP_ANTENNA
aktiv
GPS_ON/OFF
aktiv
TELEMATIK_ENABLED
aktiv
BACKUP_LOUDSPEAKER
aktiv
aktiv
ACK_2_AIRBAG
aktiv
ALIVE_SIGNAL
nicht_aktiv
CAS_KEY_DATA_METHOD
wert_01
AKIRA_MEMS/GATS
gats
PAY_TMC_CONTROL
nicht_aktiv
wireless_car_prod
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
nummer2
RDU_CONTROL
nicht_aktiv
SVR_CONTROL
aktiv
wert_01
Now,
aktiv
TRACK_WIDTH
e60_e61
WHEEL_CIRCUMFERENCE
e60_e61
m5
WHEEL_BASE
e60
SCS_OR_SVS
scs
wert_01
NAD_EQUIPPED
aktiv
DRIVE_WHEELS
rear_wheel
wert_00
wert_01
aktiv
aktiv
SPRACHE
us
business_model
aktiv
nicht_aktiv
WAKE-UP_BY_E-CALL
aktiv
aktiv
aktiv
aktiv
TCU_TYPE
e60_us
TIMER_SMS_NACK
wert_02
aktiv
wert_02
BACKUP_ANTENNA
aktiv
GPS_ON/OFF
aktiv
TELEMATIK_ENABLED
aktiv
BACKUP_LOUDSPEAKER
aktiv
aktiv
ACK_2_AIRBAG
aktiv
ALIVE_SIGNAL
nicht_aktiv
CAS_KEY_DATA_METHOD
wert_01
AKIRA_MEMS/GATS
gats
PAY_TMC_CONTROL
nicht_aktiv
wireless_car_prod
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
atxeu_preprod_d1
wireless_car_prod
nummer2
RDU_CONTROL
nicht_aktiv
SVR_CONTROL
aktiv
wert_01
Could you explain step by step how can i configure the first two points:
thank you in advance
My Ride: BMW 545i 2004, Chevy Camaro '67
No, with my original TCU being before the built date that enables this did not bother as for me it's not worth the price of a newer TCU that has this functionality.
IIRC if your built date on TCU is before March 2004, you'll be in same boat as me....
I instead installed a BT music streaming PC Board to stream music thru the car radio and use my cell phone on speaker when needed.
DavaiLave
08-02-2022 02:16 AM
