2004 e60 bluetooth %100 fix, solution
2 months ago I bought 2004 e60 (03/25/2004 production),
After check the VIN I saw it has bluetooth option but it is not in iDrive and story started. for two months I started to research to how to enable I think I checked %90 online forums. I had no idea about the coding the car. Then I bought the cable, DIS, TIS, SSS/GT1, INPA,Ncsexpert, NCSdummy. I can't use SSS (Wmware problems). I started with INPA (I learned it just for Diag and clear error codes.) Then I start the using NCSexpert and NCSDummy (I suggest, they are perfect tools, if you know how to use it.) Now, if you have TCU with BT function, if you cannot see BT option in iDrive, if you see BT option but cannot pair with phone, if you pair phone but can't make call, if you pair phone and make call but your voice is not going to them, if you pair and can make call but the car can not get your phone list, follow me. you are not alone :) my TCU ( 84116948921 ) 1) Enable BT in MASK, 2) set you TCUM module options same as mine. VR_EQUIPPED -- it seems not working. aktiv TRACK_WIDTH e60_e61 WHEEL_CIRCUMFERENCE e60_e61 m5 WHEEL_BASE e60 SCS_OR_SVS scs DSP_ACOUSTIC_PROFILE wert_01 NAD_EQUIPPED aktiv DRIVE_WHEELS rear_wheel DELAY_PWR_DOWN_INIT_DUR wert_00 TWO_MICROPHONES --- if others can't hear you set wert_02 wert_01 SIM_IN_TELEMATIK_READER aktiv TELEMATIK_SIM_ENABLED aktiv SPRACHE us US_BUSINESS/PROF_VARIANT business_model AIRBAG_TRIGGERED_E-CALL aktiv E-CALL_CHECK_CONTROL nicht_aktiv WAKE-UP_BY_E-CALL aktiv CUSTOMER_CALLS_OVER_GMIN aktiv E-CALL_HARDKEY_FITTED -- enables phone button on steering wheel. aktiv NON-TELEMATIC_E-CALL aktiv MOST_ASYNC_OR_CTRL_CHANNL most_control_channel TCU_TYPE e60_us TIMER_SMS_NACK wert_02 BLUETOOTH ---important aktiv E_CALL_COUNTD_DELAY_TIMER wert_02 BACKUP_ANTENNA aktiv GPS_ON/OFF aktiv TELEMATIK_ENABLED aktiv BACKUP_LOUDSPEAKER aktiv PORTABLE_BT -- important aktiv ACK_2_AIRBAG aktiv ALIVE_SIGNAL nicht_aktiv CAS_KEY_DATA_METHOD wert_01 AKIRA_MEMS/GATS gats PAY_TMC_CONTROL nicht_aktiv GATS_SMS_DESTIN_BACKUP wireless_car_prod GATS_SMS_DESTIN_DEFAULT --- important if you can pair but can't make call. wireless_car_prod GATS_SMSC_OR_AMPS_BACKUP atxeu_preprod_d1 wireless_car_prod GATS_SMSC_OR_AMPS_DFLT important if you can pair but can't make call. atxeu_preprod_d1 wireless_car_prod NON_TELEMATIC_E_CALL_NR nummer2 RDU_CONTROL nicht_aktiv SVR_CONTROL aktiv PHONEBOOK_PRIORITY ---- important if you can pair but car can't read phone book.. wert_01 |
and my mask trace;
K931D_ZV_ALLE_TUEREN par_frei K931D_ZV_SELEKTIV par_frei K930E_ZV_VER_N_XMIN_FB fkt_frei K9901_WARNBLINKEN par_gesperrt K9323_ZV_VER_AB_X_KM/H fkt_frei K8129_ZWAKO_AC_EIN_AUTO fkt_gesperrt K7504_HEIMLEUCHTEN_AUS par_frei K7504_HEIMLEUCHTEN_40S par_frei K7504_HEIMLEUCHTEN_90S par_frei K7504_HEIMLEUCHTEN_150S par_frei K7504_HEIMLEUCHTEN_240S par_frei K4328_BLINKEN_TIPPBET fkt_frei K5303_GAL_SEHR_STARK par_frei K8116_KLAPPENAUTOMATIK fkt_gesperrt K5303_GAL_STARK par_frei K5303_GAL_MITTEL par_frei K5303_GAL_GERING par_frei K5303_GAL_SEHR_GERING par_frei K5303_GAL_KEINE_ANHEB par_frei K5305_KLANG_BASS par_frei K5305_KLANG_TREBLE par_frei K5305_KLANG_BALANCE par_frei K5305_KLANG_FADER par_frei K5305_KLANG_REVERB par_frei K5305_KLANG_EQULIZER par_frei K531A_LAUTST_NAV par_frei K531A_LAUTST_VERKEHR par_frei K531A_LAUTST_TELEFON par_frei K531A_LAUTST_SVS par_frei K531A_LAUTST_PDC par_frei K4310_ANZ_SPRACHE_1 par_frei K4310_ANZ_SPRACHE_2 par_frei K4310_ANZ_SPRACHE_3 par_frei K4110_VERBR_L/100KM par_frei K4110_VERBR_MPG_US par_frei K4110_VERBR_MPG_UK par_frei K4110_VERBR_KM/L par_frei K410D_EINHEITEN_WEG fkt_frei K4113_ZEIT_STD_DARST fkt_frei K4116_EINH_TEMPERATUR fkt_frei K9901_UMLUFT_EIN par_frei K9901_NAV_LETZER_HINWEIS par_frei K9901_KOMFORT_PARKBREMSE par_frei K9901_MUTE_EIN par_frei K9901_MONITOR_EIN par_frei K9901_LENKRADHEIZUNG par_frei K9901_RADIO/TELEFON par_frei K9901_SWR par_gesperrt K430C_DATUM_FORMAT fkt_frei C750A_SCHWELLWERT_EMPFIN par_gesperrt C750A_SCHWELLWERT_NORMAL par_gesperrt C750A_SCHWELLWERT_SEHR_E par_gesperrt DRUCK_EINHEIT psi K8601_SOLLWERT_M3 par_gesperrt K8601_SOLLWERT_M2 par_gesperrt K8601_SOLLWERT_M1 par_gesperrt K8601_SOLLWERT_0 par_gesperrt K8601_SOLLWERT_P1 par_gesperrt K8601_SOLLWERT_P2 par_gesperrt K8601_SOLLWERT_P3 par_gesperrt K4D01_OFF_CID_DISPL_HELL fkt_frei BLUETOOTH_FIX aktiv K4119_DRUCK_BAR par_frei K4119_DRUCK_PSI par_frei K4119_DRUCK_KPA par_frei K8313_GEBLAESE_M10 par_gesperrt K8313_GEBLAESE_0 par_gesperrt K8313_GEBLAESE_P10 par_gesperrt K9901_HUPE par_gesperrt PHONE_MULF nicht_aktiv C940C_QUITT_OPT_ENTSCH fkt_gesperrt C940D_QUITT_OPT_SCHAERF fkt_gesperrt C940A_QUITT_OPT_ENTSCH fkt_frei C9419_QUITT_OPT_KLAPPE fkt_frei C9410_QUITT_OPT_SCHAERF fkt_frei C941C_QUITT_AKUST_KLAPPE fkt_frei K9416_QUITT_AKUST_ENTSCH fkt_frei C9413_QUITT_AKUST_SCHAERF fkt_frei K8119_PRG_AUTOMATIK par_gesperrt K8119_PRG_LUFTVERTEILUNG par_gesperrt K8127_KLAPPENPROGRAMM_BO fkt_frei K8119_PRG_GEBL_AKTUELL par_gesperrt K8119_PRG_SCHICHTUNG par_gesperrt K8119_PRG_AC par_gesperrt K8125_KLAPPENPROGRAMM_BO fkt_frei K532F_SENDERLISTE_AUDIO fkt_gesperrt K4D01_OFF_HUD_DISPL_HELL fkt_gesperrt K4D03_ANZEIGE_GESCHWNDGKT par_gesperrt K4D03_ANZEIGE_CHECKCONTRL par_gesperrt K4D03_ANZEIGE_ACC par_gesperrt K4D03_ANZEIGE_TEMPOMAT par_gesperrt K4D03_ANZEIGE_NAVIGATION par_gesperrt K2407_PDC_MONITORBILD fkt_gesperrt CA107_AUT_VERST_DEAKT par_frei CA107_AUT_VERST_ENTR par_frei CA107_AUT_VERST_ENT_T par_frei C9C03_KLAPPENWINKEL fkt_gesperrt C9C01_HKL_TASTE fkt_gesperrt K931D_SCHEIBENABSENKUNG par_gesperrt NIVI nicht_aktiv VOLUME_MAXIMUM_TEL e70 e91 max2 standard VOLUME_MAXIMUM_ON e92_stereo max1 standard VOLUME_AUDIO_1 e60 e70_stereo e92_hifi e93_hifi VOLUME_MINIMUM_NAVI e92_stereo max1 standard VOLUME_DELTA_NAVI_ENTER e92_stereo min3 standard VOLUME_MINIMUM_TM e70_stereo e92_hifi e92_stereo e93_hifi min1 standard VOLUME_MINIMUM_TEL e92_stereo min1 standard VOLUME_DELTA_TEL_ENTER e70_stereo e92_hifi e92_stereo e93_hifi max1 standard VOLUME_KLANG_1 e60_hifi e61_hifi KLANG_OFFSET e70_stereo e92_hifi e92_stereo e93_hifi e93_stereo min1 standard VOLUME_PDC e60_hifi e63_hifi e64_hifi e70_hifi e82_top_hifi e92_stereo max2 VOLUME_DELTA_PDC_ENTER e87_stereo max2 standard VOLUME_SECUR_1 e60 e70_stereo e87 e92_hifi e92_stereo e93_hifi LOUDNESS e60 GAL_MAIN e60 GAL_DEFAULT e60 MUTE_ON_CRASH nicht_aktiv KEY_MEMORY_ASK aktiv MUTEMIX_TIME e60 pl2 DAUER e60 pl2 ABSTAND_IDENT_PRIO e60 pl2 NACHLAUF_INT e60 pl2 TIMEOUT_INT e60 pl2 HIGH_CUT auto EINH_MASTER aktiv VOLUME_MINIMUM_SPEECH e92_stereo min1 standard AUDIO_ENTERTAIN_1 us LUEFTER_SCHW1 e60 pl2 LUEFTER_SCHW2 e60 pl2 LUEFTER_WERT1 e60 pl2 LUEFTER_WERT2 e60 pl2 LUEFTER_WERT3 e60 pl2 LUEFTER_WERT4 e60 pl2 SINGLE_TUNER aktiv DOUBLE_TUNER nicht_aktiv CDC nicht_aktiv MMC nicht_aktiv TOP_HIFI nicht_aktiv EQUALIZER aktiv VOLUME_ADJ_1 e60_hifi e61_hifi e63_hifi VOLUME_ADJ_2 e60_hifi e61_hifi e63_hifi VOLUME_ADJ_3 e60_hifi e61_hifi e63_hifi VOLUME_ADJ_4 e60_hifi e61_hifi e63_hifi SDARS nicht_aktiv SITZHEIZUNG aktiv ECE_TELEFON nicht_aktiv PHONE_BUSINESS aktiv PHONE_PROF aktiv BMW_ASSIST aktiv HELPNET nicht_aktiv BMW_ONLINE aktiv PDC nicht_aktiv ABSENK_ENTERTAINMENT_PDC e70 e87_hifi e87_stereo ein SHOW_PDC nicht_aktiv RDC nicht_aktiv HUD nicht_aktiv ELDRVSEAT aktiv MFL_HORN nicht_aktiv MFL_HAZARD nicht_aktiv MFL_CLEAN nicht_aktiv FOND_LOW nicht_aktiv LAENDERVARIANTE_TUNER us RDS_AF_FUNKTION rds_ein_af_aus TP_FUNKTION tp TP nicht_aktiv TMC nicht_aktiv AMBANDS aktiv FILTER_FZG_BLOCK_1 e60_hifi FILTER_FZG_BLOCK_2 e60_hifi FILTER_FZG_BLOCK_3 e60_hifi FILTER_FZG_BLOCK_4 e60_hifi PHASE_BLOCK e60_flat e60_hifi e70_hifi e70_stereo e82_stereo e87_hifi e87_stereo_old e88_stereo e90_hifi e90_stereo e91_stereo e92_hifi e93_hifi pl2_hifi CROSS_OVER_1 e60_hifi e70_hifi CROSS_OVER_2 e60_hifi e70_hifi OUTPUT_GAIN_SYSTEM e60_hifi e70_hifi BAUREIHE e60 CODIERUNG_ERFOLGT codierung_erfolgt TYP_LENKUNG linkslenker OUTPUT_SIGNAL_TABLE_1 e60_ll e60_rl e70_ll e70_rl pl2_ll pl2_rl OUTPUT_SIGNAL_TABLE_2 e60_ll e60_rl e70_ll e70_rl pl2_ll pl2_rl ACC nicht_aktiv CRUISE_CTRL aktiv WAEHLBARE_SPRACHE_1 us WAEHLBARE_SPRACHE_2 us WAEHLBARE_SPRACHE_3 us CID cid_mid RING aktiv WEG_EINHEIT mls BC_HIGH aktiv KLIMA_SG_ART high STANDLUFT aktiv DWS aktiv BMW_N_DEALER aktiv TRF nicht_aktiv KANA_WRITER nicht_aktiv SMS aktiv PTY_TABELLE pty_us WEATHERBAND aktiv LEGAL_DISCL nicht_aktiv REV_INPUT aktiv UNIT_FEET aktiv ACOUSTIC aktiv REGIONALISIERUNG reg_aus TEMPERATUR_EINHEIT grad_f ZEIT_EINHEIT 12_stunden DATUM_EINHEIT mm_tt_jj SPEECH_MF weiblich VERBRAUCH mpg BACKDOOR nicht_aktiv E64 nicht_aktiv STANDHEIZUNG aktiv AUXIN aktiv FLAP nicht_aktiv PDC_LOW nicht_aktiv VOLUME_KLANG_EMERGENCY e60_hifi e70_hifi e90_hifi e91_hifi VOLUME_PDC_EMERGENCY e60_hifi e63_hifi e64_hifi e87_hifi e87_stereo SVS_LOW nicht_aktiv GALLON_VAL us MP3 aktiv AMBAND_KW aktiv AMBAND_LW aktiv AMBAND_MW aktiv OIL_LEVEL aktiv NAVIGATION_MASK aktiv CBS_MODE level_3 PIA_LEVEL level_1 SENDER_TAB_HGL nicht_aktiv AUTO_DRV_LIGHT nicht_aktiv HDC nicht_aktiv MDRIVE nicht_aktiv MDRIVE_ALBV nicht_aktiv MDRIVE_SMG aktiv VA_BPI nicht_aktiv AUDIO_SYSTEM_MASK e60_hifi e90_hifi pl2_hifi DISPLAY_LOG7_SYMBOL aktiv NAVIGATION_FLOTTENMODUS nicht_aktiv MP3CDC aktiv NEUSEELAND nicht_aktiv BLUETOOTH_NODES_MASK profil_2 BMW_DEALER_MASK aktiv BMW_HOTLINE_MASK aktiv BMW_MOBILE_MASK aktiv DAB nicht_aktiv DAB_BAND_SETTINGS nicht_aktiv DAB_FM_SWITCH nicht_aktiv DAY_RUN_LIGHT_MASK aktiv IBOC nicht_aktiv CODIER_CHECK aktiv LOGISTIK_CHECK aktiv DSC_IN_MDRIVE nicht_aktiv FBM_COMMUNICATION nicht_aktiv FBM_ENTERTAINMENT nicht_aktiv FBM_FMAM_TOGGLE nicht_aktiv FBM_MODE_TOGGLE nicht_aktiv FBM_NAVIGATION nicht_aktiv FBMS nicht_vorhanden HANGUL_TYPEWRITER nicht_aktiv KANJI_TYPEWRITER nicht_aktiv MOST_ASYNC_CTRL_CHANNL most_control_channel RAMP_CONTROL nicht_aktiv SEATVENTILATION nicht_aktiv SITZHEIZUNG_SLIDER nicht_aktiv FOND_MID nicht_aktiv LAST_PANEL_TIMEOUT e6x e70 e89 LEGAL_DISCL_TIMEOUT e6x e70 e89 MANUAL_SHIFT nicht_aktiv NOAIRVENT_FINE nicht_aktiv CAR_COLOR_CHAMP nicht_aktiv |
2004 545i
That's exactly what I been looking for months. Do you have to make change to all lines you have listed? If not, can you summaries just the ones that need to be change? I will get my cable/program in couple of weeks. |
Originally Posted by miuth
(Post 1489366)
2004 545i
That's exactly what I been looking for months. Do you have to make change to all lines you have listed? If not, can you summaries just the ones that need to be change? I will get my cable/program in couple of weeks. BLUETOOTH_FIX aktiv PHONE_MULF nicht_aktiv ECE_TELEFON nicht_aktiv PHONE_BUSINESS aktiv PHONE_PROF aktiv BMW_ASSIST aktiv HELPNET nicht_aktiv BMW_ONLINE aktiv RING aktiv SMS aktiv BLUETOOTH_NODES_MASK // if can't upload phone book try other options profil_2 BMW_DEALER_MASK aktiv BMW_HOTLINE_MASK aktiv BMW_MOBILE_MASK aktiv BMW_N_DEALER aktiv IBOC nicht_aktiv TCUM Unit TWO_MICROPHONES --- if others can't hear you set wert_02 wert_01 SIM_IN_TELEMATIK_READER aktiv TELEMATIK_SIM_ENABLED aktiv SPRACHE us US_BUSINESS/PROF_VARIANT business_model AIRBAG_TRIGGERED_E-CALL aktiv E-CALL_CHECK_CONTROL nicht_aktiv WAKE-UP_BY_E-CALL aktiv CUSTOMER_CALLS_OVER_GMIN aktiv E-CALL_HARDKEY_FITTED -- enables phone button on steering wheel. aktiv NON-TELEMATIC_E-CALL aktiv MOST_ASYNC_OR_CTRL_CHANNL most_control_channel TCU_TYPE e60_us TIMER_SMS_NACK wert_02 BLUETOOTH ---important aktiv E_CALL_COUNTD_DELAY_TIMER wert_02 BACKUP_ANTENNA aktiv TELEMATIK_ENABLED aktiv PORTABLE_BT -- important aktiv GATS_SMS_DESTIN_BACKUP wireless_car_prod GATS_SMS_DESTIN_DEFAULT --- important if you can pair but can't make call. wireless_car_prod GATS_SMSC_OR_AMPS_BACKUP atxeu_preprod_d1 wireless_car_prod GATS_SMSC_OR_AMPS_DFLT important if you can pair but can't make call. PHONEBOOK_PRIORITY ---- important if you can pair but car can't read phone book.. if not work try other options. wert_01 Thanks |
Any chance you could also post the VO, I have added +K633 and tried also with +TELD but neither one of any combinations is working for me, all is working EXCEPT the callers cannot hear me.....
Also have the refitted 2005 TCU version installed by dealer years ago and since I bought the car BT was not enabled . |
Good stuff
Originally Posted by karayakar
(Post 1482843)
After check the VIN I saw it has bluetooth option but it is not in iDrive and story started. for two months I started to research to how to enable I think I checked %90 online forums. I had no idea about the coding the car. Then I bought the cable, DIS, TIS, SSS/GT1, INPA,Ncsexpert, NCSdummy. I can't use SSS (Wmware problems). I started with INPA (I learned it just for Diag and clear error codes.) Then I start the using NCSexpert and NCSDummy (I suggest, they are perfect tools, if you know how to use it.) Now, if you have TCU with BT function, if you cannot see BT option in iDrive, if you see BT option but cannot pair with phone, if you pair phone but can't make call, if you pair phone and make call but your voice is not going to them, if you pair and can make call but the car can not get your phone list, follow me. you are not alone :) my TCU ( 84116948921 ) 1) Enable BT in MASK, 2) set you TCUM module options same as mine. VR_EQUIPPED -- it seems not working. aktiv TRACK_WIDTH e60_e61 WHEEL_CIRCUMFERENCE e60_e61 m5 WHEEL_BASE e60 SCS_OR_SVS scs DSP_ACOUSTIC_PROFILE wert_01 NAD_EQUIPPED aktiv DRIVE_WHEELS rear_wheel DELAY_PWR_DOWN_INIT_DUR wert_00 TWO_MICROPHONES --- if others can't hear you set wert_02 wert_01 SIM_IN_TELEMATIK_READER aktiv TELEMATIK_SIM_ENABLED aktiv SPRACHE us US_BUSINESS/PROF_VARIANT business_model AIRBAG_TRIGGERED_E-CALL aktiv E-CALL_CHECK_CONTROL nicht_aktiv WAKE-UP_BY_E-CALL aktiv CUSTOMER_CALLS_OVER_GMIN aktiv E-CALL_HARDKEY_FITTED -- enables phone button on steering wheel. aktiv NON-TELEMATIC_E-CALL aktiv MOST_ASYNC_OR_CTRL_CHANNL most_control_channel TCU_TYPE e60_us TIMER_SMS_NACK wert_02 BLUETOOTH ---important aktiv E_CALL_COUNTD_DELAY_TIMER wert_02 BACKUP_ANTENNA aktiv GPS_ON/OFF aktiv TELEMATIK_ENABLED aktiv BACKUP_LOUDSPEAKER aktiv PORTABLE_BT -- important aktiv ACK_2_AIRBAG aktiv ALIVE_SIGNAL nicht_aktiv CAS_KEY_DATA_METHOD wert_01 AKIRA_MEMS/GATS gats PAY_TMC_CONTROL nicht_aktiv GATS_SMS_DESTIN_BACKUP wireless_car_prod GATS_SMS_DESTIN_DEFAULT --- important if you can pair but can't make call. wireless_car_prod GATS_SMSC_OR_AMPS_BACKUP atxeu_preprod_d1 wireless_car_prod GATS_SMSC_OR_AMPS_DFLT important if you can pair but can't make call. atxeu_preprod_d1 wireless_car_prod NON_TELEMATIC_E_CALL_NR nummer2 RDU_CONTROL nicht_aktiv SVR_CONTROL aktiv PHONEBOOK_PRIORITY ---- important if you can pair but car can't read phone book.. wert_01 Could you explain step by step how can i configure the first two points: 1) Enable BT in MASK, 2) set you TCUM module options same as mine thank you in advance :) |
Originally Posted by cmyachtie
(Post 1507573)
No, with my original TCU being before the built date that enables this did not bother as for me it's not worth the price of a newer TCU that has this functionality.
IIRC if your built date on TCU is before March 2004, you'll be in same boat as me.... I instead installed a BT music streaming PC Board to stream music thru the car radio and use my cell phone on speaker when needed. |
